I think my engine is gonna go.
Ok, in the last 3 weeks my engine has started blowing more and more blue smoke. It was originally only on startup but now its whenever I get on it or just go. It stinks up the inside of my car and I cant stand it. So I think its time to rebuild the engine. So roughly how much would it cost to rebuild the engine at a shop and have them bore it out .60 over? Its a 305. I dont know how to do it myself and all my friends are worthless. Please, no 305-350 wars. I have been searching for 350s in the area and havent had any luck. Im thinking it would be cheaper to just rebuild the engine I have. Anyways Im open for any opinions but IF THIS TURNS INTO A WARZONE I WILL CLOSE THIS THREAD BEFORE THE MODS DO.
Sorry, on a power trip
Thanx guys.
P.S. Anyone in my area want to rebuild it??
Thanx guys. P.S. Anyone in my area want to rebuild it??
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Are you sure the 'new' blue smoke is actually burning inside the engine? It could be your valve cover gaskets leaking oil onto the exhaust manifolds or onto the intake manifold. I would first check the engine to see if there is oil on it anywhere.
i think i'd leak it or run a compression test before i go as far as pull the engine and rebuild it. last block i had cleaned, bored, cam bearings and freeze plugs cost me 150 dollars which from what i read on here is unreal cheap. i'd only go +.030 on the over bore unless it needed .060. best thing to do about prices is get the yellow pages out and call shops in your area and ask. too much varation from area to area for prices here to matter to you there.
Damn Incompetence! Ede, so all that stuff you got done? Is that considered a partial rebuild or what? My main concern is to quit burning oil and keep my car running..
that was just for cleaning the block, install cam bearings, freeze plug, bore +.030, and resurface the deck. i usually charge 350 to 400 to take apart, clean, measure and rebuild an engine back to stock specs. parts and machine work is at owners option and expense. i've saw chucks car and you won't find a better looking thirdgen anywhere. the paint is unreal and he hasn't sanded it or buffed it out yet.
Ok anywhoo. Not to be a moron, but what do you think I should do. I know you answered this but Im not really quite sure what you mean. So, I dont need the engine rebuilt? The car runs great but is starting to burn oil. If I could find a 350 to put in there Id do it but I cant find squat around here. Supreme Member
Car: 83Z28 HO
Transmission: G Force 5 speed
That's a
seriously low price. I paid $920.00 for the machine work on mine!!
Of course I had the heads rebuilt too, with teflon seals added..
Of course I had the heads rebuilt too, with teflon seals added.. Joined: Jul 2000
Car: `86 SS / `87 SS
Really bad valveguide seals can cause blue smoke.
Do a compression check. If it's good, do your valve guide seals.
Matthew
Matthew
ede's price quote is about the same here in louisiana. You bring them the unassembled engine
165.00 vat clean, bore, install cam bearings and freeze plugs
20.00 polish crank ( could be all it needs)
58.00 turn crank
32.00 hang pistons on rods
150.00 head work: resurface,install bronze valve guide liners,
three angle valve job (valves,springs are
extra)
300.00 my price for disassembly, cleaning and reassembly.
450.00 rough estimate for s/r rings,rod & main bearings, gaskets
timing set,cam & lifters,oil pump and screen, pistons
Labor for engine removal and installation will vary from shop to shop.
Lonnie
58.00 turn crank
extra)
Lonnie
