it was so hot in my car that i caught fire,
Old Jul 28, 2002 | 08:21 PM
BOTTLEDZ28's Avatar
Transmission: A4
It gets so hot inside my car that i cant even rest my arm on the center console. The heat that comes up from the tranny must be 175 degrees. i have small burn marks on my arms from the screws on the console. I doubt my radio is gonna much longer. what can i do to stop the heat from coming in. I know there is Special stuff out there for this but its $100 for square foot. I also want to keep the noise out too. will dyno mat keep heat out or is there another material i can use to block both heat and noise at the same time. please help soon im losing 10lbs a day from sweating so much
Old Jul 28, 2002 | 08:39 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
hey...... lend me your car for a week or so? i need to lose some weight
Old Jul 28, 2002 | 09:40 PM
Vader's Avatar
Rent your car as a "rolling sauna" for a few weeks to accumulate some cash. The insulation blankets may be expensive, but are the best answer to your heat radiation problem. Getting some air flow under the car would help a little, too.
Old Jul 28, 2002 | 09:51 PM
mimgq2's Avatar
Tune-up
Your car is running too LEAN it the headers are real hot. To Rich if your cat is red hot.
Old Jul 28, 2002 | 10:44 PM
Ratstix's Avatar
sounds as if you have a clogged up cat, my friend.
Old Jul 28, 2002 | 10:49 PM
Vettetrax's Avatar
Car: Camaro Z28
Transmission: auto
Re: it was so hot in my car that i caught fire,
i HATE those screws when they are hot! also my power window buttons are there and they burn too. i had little burns for a week one time because of those... but mine get hot from the sun being on them all day not the tranny?
Old Jul 29, 2002 | 12:35 AM
RBud350tpi's Avatar
I put a transmission cooler on my 87 and it cut the heat I feel from the trans tunnel in half. the best 35 bucks I spent all month if you ask me.
Old Jul 29, 2002 | 01:45 AM
TBI305Camaro's Avatar
I second that....i spent 30$ on a tranny cooler really seemed to help my shifts and the car runs alittle better.
Old Jul 29, 2002 | 02:06 AM
Kevin Johnson's Avatar
Truechoice has aluminized heat cloth that is $43.95 per square yard (nine square feet).
1-800-388-8783
www.truechoice.com
But definitely check the other suggestions to ensure that something isn't malfunctioning etc.
9192camaro
16
Feb 3, 2019 12:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
apie2546
Aug 10, 2015 05:43 PM
djmarch
Aug 9, 2015 05:27 PM
