Tach won't zero when shut off...
Old Jul 29, 2002 | 03:16 PM
91TealRS's Avatar
My '86 IROC's tach won't go to zero when you shut it off. Whatever RPM it was at (idle) it stays at when you turn the car off. BUT...when you turn the ignition on (not starting but the ACC), it will zero. Any thoughts?
Old Jul 29, 2002 | 03:17 PM
iroc22's Avatar
It's an electronic tach. They do that.
Old Jul 29, 2002 | 03:23 PM
91TealRS's Avatar
so...no quick way to fix? just live with it huh?
Old Jul 29, 2002 | 03:58 PM
snjracer's Avatar
my auto meter tach does the same.. it is not broken.. so it does not need to be fixed
edit... if it really pisses you off. you can shut the car off to the accesories position for a 1/4 second b4 shutting all the way down and it should 0 out
Old Jul 29, 2002 | 04:44 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Yea, but as soon as he slams the door it'll pop back up!
Try tapping on the dial faces or the dash above the dials...see how high you can get the needle! I got mine to 4,500 before I got bored.
Si
Old Jul 29, 2002 | 05:56 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
like everyone said its just the way of life. it really bothers you that bad?
Old Jul 29, 2002 | 06:27 PM
Vettetrax's Avatar
Car: Camaro Z28
Transmission: auto
mine does that too, it's normal
Old Jul 30, 2002 | 11:01 AM
91TealRS's Avatar
Hellno it doesn't bother me that bad! i was just wondering why it did that and if there was a quick fix. don't worry, i won't be in bed tonight dreaming about killer tachs that won't zero coming after me. :lala:
Old Jul 30, 2002 | 11:11 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
What you gotta realize is, when the car's off, the RPMs are actually, in fact, at zero, regardless of the tach reading. Therefore, these guages are highly inaccurate, stating that the engine is running when in fact it's sitting still... it must be fixed!
Hehe, just messin'
Old Jul 30, 2002 | 01:16 PM
Vettetrax's Avatar
Car: Camaro Z28
Transmission: auto
all it means is when you turn the key off, you kill the tach before the engine comes to a complete stop. therefor the tach reads the last rpm before it was turned off
Old Jul 30, 2002 | 01:35 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
These are the stock tachs? Here is a fix. Get a autometer tach.
Old Jul 31, 2002 | 01:00 AM
91TealRS's Avatar
so, just curious and bored, if it was 1986 and I bought this brand new IROC, the tach would do this even new? Is this true, or is it just something that happens over age?
Old Jul 31, 2002 | 01:06 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
My aftermarket Autometer tach does not do that. Must be a GM thing. That would iritate me too, but anything that does not work iritates me.
Old Jul 31, 2002 | 01:29 AM
evil t/a's Avatar
Why in the hell do you care what your tach reads while the engine isnt running?
Old Jul 31, 2002 | 02:16 AM
kev_n_ang_ta's Avatar
Car: 1984 TA, 2001 Monte Carlo SS
Engine: 305 LG4, 3.8 200 HP
life not fair
I have a 2001 Monte Carlo and when the key is off the gas gage reads E does that mean Im out of gas my 84 Trans Am say 3/4 and I just filled both of them up. Im just saying some gages zero out and some dont.
Old Jul 31, 2002 | 02:21 AM
life not fair
Old Jul 31, 2002 | 03:05 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Old Jul 31, 2002 | 11:47 PM
91TealRS's Avatar
excuse the hell outa me!
Old Aug 1, 2002 | 01:09 AM
deadtrend1's Avatar
Its normal. Its like the guages on newer gm cars will max out when you cstart the car to calibrate themselves or something, then read the correct readings.
If the tach pegged when you started the car like my 87 camaro did, then you have a problem. I fixed that easily ... with a swift punch to the dash! And the amazing part was that it worked after that. No lie ...
~Tim
Old Aug 1, 2002 | 03:17 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
mine did that too no biggie, before the motor blew today
Old Aug 1, 2002 | 03:56 AM
Engine: 406
~Tim
Thats how I get my Volt gauge to work..
Old Aug 2, 2002 | 01:57 AM
LottaBallsCamaro's Avatar
I do the same to my Nissan pickup every day.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 22, 2015 03:19 PM
TrevinE
Sep 14, 2015 03:20 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
