Low Oil Pressure
Old Jul 30, 2002 | 06:22 PM
THE SANDMAN's Avatar
Car: 1983 Camaro
Engine: 5.7
Low Oil Pressure
I noticed the oil pressure was low in my rebuilt engine which has 0 miles on it so far. The stock gauge said 30 psi. at idle and the new sunpro gauge says 0psi at idle. When i rev it up the gauge moves slightly up about 10 psi. The engine feels strong and it doesn't feel like it wants to stall or die. There is also oil where the rockers are so I know i'm getting oil. Any ideas?
Old Jul 30, 2002 | 06:34 PM
ede's Avatar
ede
screw a good gauge in the block and see what you have
Old Jul 30, 2002 | 09:13 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Yeah, a good mechanical guage will tell you better.
If it's still low, maybe a galley plug was left out somewhere or bearing clearences are too wide. Also some new pumps have too much end clearance.... I've seen that before. Hope it's just a bad guage... Otherwise
Old Jul 31, 2002 | 07:29 PM
Car: 1983 Camaro
Engine: 5.7
I finally put a new mechanical Sunpro gauge in and i plugged it directly into the block. I started the car and it read 0 psi. at idle and about 20 psi. at 3000.
Old Jul 31, 2002 | 07:41 PM
Polecat's Avatar
Where are you plugging it? If you have at least full oil on the dipstick, you almost have to have some type of pressure.......
Old Jul 31, 2002 | 07:43 PM
Car: 1983 Camaro
Engine: 5.7
I screwed it directly into where the stock pressure sending unit goes.
Old Jul 31, 2002 | 07:44 PM
Polecat's Avatar
Who did the overhaul?
Old Jul 31, 2002 | 07:46 PM
Car: 1983 Camaro
Engine: 5.7
I did the whole engine myself. Everything is new except the crank, rods, and oil pan.
Old Jul 31, 2002 | 07:53 PM
Polecat's Avatar
Pull a valve cover, be sure your getting oil to the top of the head. Be sure you have full oil, and are you sure the oil pickup was installed at the right height?
Old Jul 31, 2002 | 07:55 PM
Car: 1983 Camaro
Engine: 5.7
I am getting oil at the top of the head. Pretty sure i have the pickup in the right place and i have full oil.
Old Jul 31, 2002 | 07:58 PM
Polecat's Avatar
So you are using mechanical gauges...not electric?
I would lead to believe there is something wrong with the gauges...but you have tried two different ones?
Old Jul 31, 2002 | 08:03 PM
Car: 1983 Camaro
Engine: 5.7
I have no idea what could be wrong. The stock electric one said 30 at idle and the new mechanical one says 0 at idle but there is no ticking from the lifters to tell me i'm not getting oil. So i'm gonna buy a new mech. gauge tomorrow just incase the other one has something wrong with it.
Old Jul 31, 2002 | 08:04 PM
Polecat's Avatar
If you have oil, you have to have some oil pressure....do a total mechanical setup, with a new gauge......and let me know.
Old Jul 31, 2002 | 08:07 PM
Car: 1983 Camaro
Engine: 5.7
ok i'll be sure to post tomorrow telling you how it turned out.
Old Jul 31, 2002 | 08:08 PM
Polecat's Avatar
Sounds good...good luck man!
Old Jul 31, 2002 | 08:09 PM
ronterry's Avatar
Car: '94 Corvette
I would still be a little icky about 30 @ idle when it's cold!!!
That mean it'll drop to 5 after the oil gets hot!!!
Ron
Old Jul 31, 2002 | 08:10 PM
Car: 1983 Camaro
Engine: 5.7
I'm worried i'm gonna lose my engine. That's why i wanna make sure i have enough pressure.
Old Jul 31, 2002 | 08:11 PM
Polecat's Avatar
Still sounds like the gauge....just my opinion...
Old Jul 31, 2002 | 08:14 PM
Car: 1983 Camaro
Engine: 5.7
I think it's the gauge too.
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
