Dip Stick Oil keeps coming out of it HELP!!!! any one
Old Aug 1, 2002 | 08:35 PM
bj350hp's Avatar
Car: 1987 Camaro SC
Old Aug 1, 2002 | 08:56 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Is it all the way in, bent, kinked, or oil over filled?
If not you can put some high temp gasket maker around the block hole. Just make sure you clean all oil residue from the hole and tube first.
Old Aug 1, 2002 | 11:03 PM
ronterry's Avatar
Car: '94 Corvette
I usualy coat the part that goes into the block with Lock tight.
Not only does keep the tube in, it usualy seals it. There's not a whole lot of pressure there to deal with.
Ron
Old Aug 4, 2002 | 11:41 PM
bj350hp's Avatar
Car: 1987 Camaro SC
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
the_nikfive
Aug 11, 2015 02:46 AM
gwade12
Aug 8, 2015 08:17 AM
Leggman1
Aug 6, 2015 04:15 AM
