What do you guys gap your plugs at??????
Old Aug 2, 2002 | 06:35 AM
jfox55's Avatar
I bought a set of ac delco's I am putting in today. They say to gap them at .45, but I have the accel super coil so I was thinking I would gap them at .50. What do you guys think??? What do you gap yours at??? My car and engine is in my sig.
__________________
Old Aug 2, 2002 | 07:49 AM
ede's Avatar
ede
don't really matter what i use more important is what your engine combo likes. i use .045. try .050 and see what happens, try something else and see if it's better or worse.
Old Aug 2, 2002 | 08:37 AM
88IROC-LT1's Avatar
Underneather the hood, there is a sticker (on the bottom of the hood). It will tell you the gap , the timing, the belts, and other stuff!
Old Aug 2, 2002 | 08:58 AM
darbleinad's Avatar
Car: 84 Trans Am
i have mine gapped at .045
Old Aug 2, 2002 | 01:36 PM
iroc22's Avatar
I gap mine at .035" That's whats specified for my year. I run a MSD coil and Taylor wires and I think .035" works just fine. I would probably get more power out of a wider gap though.
Old Aug 2, 2002 | 02:28 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
When I put the new plugs in I gapped them at .045, ran great. Then I read the sticker under the hood said .035, so I regapped 'em at .035. Lost power and 2 mpg. I compromised at .040, seems to work fine but .045 felt a little better. All fac. ign.
Been almost 30k and haven't checked a plug yet.
Old Aug 2, 2002 | 02:53 PM
JMDinHawaii's Avatar
A dude at the parts store told me .60 using the MSD HEI coil. Since the plugs are such a pain in the a$$ to change(still got the smog crap in the way), I couldn't bring myself to try it. I went with .45 but next plug change I'm going to give .50 a try. Anyhoo, its up to you!
Old Aug 2, 2002 | 05:01 PM
darbleinad's Avatar
Car: 84 Trans Am
.060 seems way to big, even with the MSD coil. i have an coil in cap HEI and have the MSD coil and MSD module and even then i think the highest they suggest is .055 and you should likely try .050 first.
Old Aug 2, 2002 | 05:10 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
The larger gaps, (.045-.060") are fine as long as you have a good coil and plug wires.
I run .050".
-Rich-
Old Aug 2, 2002 | 05:12 PM
darbleinad's Avatar
Car: 84 Trans Am
ya you definetly need a good ignition system to support plug gaps in excess of .055.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
mx127
Aug 10, 2015 08:13 AM
