Would you use this cam, look at the Lobe(pic)
Old Aug 6, 2002 | 03:41 PM
DFIance's Avatar
Here its not that bad, but I dont have 250 to get another one, its been run like it and smoothed out.
Attached Thumbnails Would you use this cam, look at the Lobe(pic)-dsc00365-copy.jpg
Old Aug 6, 2002 | 03:42 PM
DFIance's Avatar
another
Old Aug 6, 2002 | 03:43 PM
DFIance's Avatar
whoops
Attached Thumbnails Would you use this cam, look at the Lobe(pic)-dsc00364.jpg
Old Aug 6, 2002 | 03:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I wouldn't.
Old Aug 6, 2002 | 04:32 PM
Odyssey's Avatar
If you have to come on here and ask... if there's ANY doubts about the integrity of a lobe, do not run it !!!
Why do you say $250 ? That look like a flat tappet cam. Those cant go much over $100.
Old Aug 6, 2002 | 05:14 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
no kidding, 250 for a flat tappet? Dayam! GET A NEW ONE. trust me on this. I burned through THREE cams in the past because I tried to re-use old but "still good" cams with new lifters. 3 out of 5 times the cam will not wear right and some lobes will go round. I swear to *** this happened to me twice on one car (my firebird) and I just about pulled all my hair out till I realized it was because I was reusing an OLD cam with NEW lifters. Not a good idea. Trust me.
Old Aug 6, 2002 | 05:28 PM
DFIance's Avatar
Custom Cut=250
Old Aug 6, 2002 | 05:40 PM
evil t/a's Avatar
Originally posted by DFIance
Custom Cut=250
What are the specs on that cam?
Old Aug 6, 2002 | 08:50 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
That looks like a normal wear pattern for a flat tappet cam.
Get a dial caliper and measure the dia of the lobe and compare to some others on the cam. .002" wear is acceptable.
Inspect the old lifters. Put two of them end to end and see if they will still rock together. (still convex).
Is this cam going back into the same motor?
You can deglaze the lifter bores with a small brake cylinder hone.
This will ensure that the lifters can spin in their bores when the motor runs. Wash down the lifter bores with brake cleaner. Change the oil. This is a major cause if cam lobe failure.
What are the specs on your "custom grind". There is probabily
an off the shelf grind that will work the same or better for a lot less.
Old Aug 6, 2002 | 09:12 PM
JucinGTA's Avatar
.250/.260 .532/.555 110 lsa
Old Aug 6, 2002 | 09:16 PM
Odyssey's Avatar
jeez that's a lot of duration.
Old Aug 6, 2002 | 09:28 PM
F-BIRD'88's Avatar
XS290S-10 12-679-5 290°/296° 252°/260° .360"/.372" .540"/.558" 110° (+4)
Comp cams Extreme Energy XS290S-10 will replace this
These are a new series and not in the catalog yet.
Crane Blue racer WG5083 is the same except ground on 106
285-2M
Mech E
250 260
285 295
.533” .555”
104/108
Elgin #E1090 is a proven performer in this application
specs are 256/264 .537/.557 285/295 106
You can buy this cam and lifters set for $99 US +shipping
from Competition Products
http://www.competitionproducts.com/page48.html
Old Aug 6, 2002 | 09:57 PM
ede's Avatar
ede
who you have grind your cams, last one i had ground cost 25 dollars for the custom grind from lunati, i hope they kissed you too.
Old Aug 7, 2002 | 12:21 AM
Guest
Guest
Posts: n/a
I had a used cam reground to custom specs (thats what happens when there is no aftermarket cam available) for $30.
$250 seems like alot to me. I wouldnt use that cam either, it being flat tappet. Its gonna have that lifter for dinner.
Old Aug 7, 2002 | 09:47 AM
DFIance's Avatar
Where do you guys get yours custom cut at for 30 bucks?
U think I could have this repaired?
Old Aug 7, 2002 | 01:11 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Max,
We were wondering how old you are. But good grief, before there were aftermarket cams? Was that the paleolithic age?
Old Aug 7, 2002 | 01:19 PM
Guest
Guest
Posts: n/a
Old enough. Not referring to a SBC or similar though, not all engines have cams available. When you work with the oddball application, sometimes you gotta make do. Couldnt get pistons either (well, not for less than $200 a pop) so I cut around .060 or so off the head to raise the compression. Heh. I had that cam cut in 1993.
The place that did it was a machine shop, but not your average performance/rebuilder. They did all sorts of stuff, from mass rebuilding to straightening axles, remachining spindles, etc. You'll find many people who have a real problem with 'regrinds' but I've run a few and they've held up fine for me.
Old Aug 7, 2002 | 01:32 PM
Fast3rdGen's Avatar
my cam has 257/269 degrees of durration at .050". now thats alot of durration for a street car lol.
Old Aug 7, 2002 | 05:10 PM
Odyssey's Avatar
Question is.. can you USE all that duration ? My cam is 244/254 and I'm running some decent times.
beastin91rs
Oct 9, 2015 07:38 AM
Mickeyruder
Sep 2, 2015 02:45 PM
bdads
Aug 24, 2015 06:01 PM
cstrobel65
Aug 15, 2015 10:19 AM
