what valve springs to use with cam
Old Aug 9, 2002 | 09:05 AM
primer84z's Avatar
im getting either a XE262 or XE268 for my 305 and am curios as to what valve springs to use. i know that most of them wont fit in an unmachined 305 head, but which ones would work with out getting heads machined?
Old Aug 9, 2002 | 09:09 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I hear the 268 is a bit much for a 305, not sure though.
I got the same cam, and they told me to get the CCA-981-16 springs from Summit. $57. Good idea to get the locks and retainers to, if you get the K-Kit I think it's called you get the cam, lifters, springs, locks, retainers and a double roller chain. With this kit, you're pretty much getting the double roller for free, rather than buying things separately.
Old Aug 9, 2002 | 11:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The springs Mark mentioned will fit in an unmodified head.
His advice is good, definitely follow it if you are doing this to a virgin motor, or one whose parts you are unsure of, or one with replacement stock parts.
Old Aug 9, 2002 | 12:39 PM
primer84z's Avatar
the guy at the speed shop said i wouldnt need new springs with 262. he said stock ones would be ok. the engine was rebuilt last summer i guess they are pretty fresh. he also suggested to use the 262 because i would have to spin my motor pretty high with the 268 and i would lose a lot of low end torque.
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
