RODS92Z....what the hell is wrong with this thing
Old Aug 9, 2002 | 08:32 PM
microtek_10's Avatar
Car: 92 Z28
Engine: 355 tpi
Had a nice walk home from work tonight cuz once agian the car won't start. Didn't start this morning either when i was gonna go outa town. All electronics turn on, don't hear any sound from the fuel pump AT ALL. And everytime it won't start i don't hear anything from back there. What is wrong cuz i thought you just replaced it before i bought it?????
Old Aug 9, 2002 | 09:36 PM
deadtrend1's Avatar
It could be your VATS system. Thats the problem I was having. The Ohm readings in your key may not match the computers readings and then will shut off the fuel and ignition systems.
Or I heard stories about the fusable links making a car not start.
Edit : take a look at the security light on the dash when you turn the key. If its illuminated when you turn the key to crank, then that means its messed up.
Old Aug 10, 2002 | 10:07 AM
Car: 92 Z28
Engine: 355 tpi
The only lights that come on are the service engine soon and one that says INFL REST.....what is that light????
Old Aug 10, 2002 | 10:27 AM
91-Z-Speed's Avatar
INFL REST is your inflatable restraint (airbag) system filling up with air so that if you hit something that hits a sensor your wont blast your head on the steering wheel
Old Aug 10, 2002 | 10:29 AM
Car: 92 Z28
Engine: 355 tpi
ok then thats obviously not a bad thing. Still waitin to go check on the car
Old Aug 10, 2002 | 11:35 AM
Car: 92 Z28
Engine: 355 tpi
Well I went to get the car and it started right up. POpped the key in, pump came on and it started fine. What can cause these "no start" spells????
Old Aug 10, 2002 | 11:37 AM
91-Z-Speed's Avatar
Hmmm, I saw this probelm in a 2001 Grand am GT, too bad we never figured out what was wrong, we just hooked up some jumper cables to it for a while, revved up the jumping car, and the grand am started, thats all i know, but i can't really tell you anything otherwise
Old Aug 10, 2002 | 02:20 PM
ede's Avatar
ede
if everything else has power to it check the clutch/park safety switch and the key cylinder, fuseable link to the starter
Old Aug 10, 2002 | 03:25 PM
Car: 92 Z28
Engine: 355 tpi
the what
Old Aug 12, 2002 | 10:28 AM
Car: 92 Z28
Engine: 355 tpi
Ok the car will not start anymore. Been sittin for about 2 days and theres nothing. WTF
Old Aug 12, 2002 | 10:48 AM
flyin89's Avatar
Lets rule out some things, Anti theft (vats) would cause it NOT to turn over(meaning turn key no cranking of engine at all) IF it is turning over the fuel pump should come on for a few sec. then go off Either its not getting current (re:fuse or relay check the wires at the tank) or if its got current to the wires the tank then it is the fuel pump. My .02!
Old Aug 12, 2002 | 11:25 AM
Car: 92 Z28
Engine: 355 tpi
When i turn the key everything turns on except the pump....I can turn the key and the engine just cranks and cranks but won't come start.
Old Aug 12, 2002 | 11:43 AM
flyin89's Avatar
Then as stated above its not the anti-theft. Time to disconnect the wires going to the tank take a test light and see if it is getting current to the tank.
Old Aug 12, 2002 | 12:06 PM
Car: 92 Z28
Engine: 355 tpi
Where exactly are these wires? Do i have to drop the tank? or are they at the engine??
Old Aug 12, 2002 | 12:42 PM
flyin89's Avatar
No you don't have to pull the tank to check the wiring. Jack up the rear of the car you should be able to see a four or five wire connector coming from the tank. This is the connector to test.
Old Aug 12, 2002 | 12:53 PM
Car: 92 Z28
Engine: 355 tpi
wheres the connector? I mean like which side of the tank.
Old Aug 12, 2002 | 01:18 PM
SlowStangEater's Avatar
Check the Accessory wire coming off the positive battery cable. Its the little wire coming off the big one. It goes to a little post next to the battery which powers all your accesories. If this wire is loose your starter will turn but not start. But if the engine actually cranks and doesnt start then this is most likely NOT the case. Just something to marinate on
Old Nov 8, 2002 | 03:36 PM
therym's Avatar
HELP!
My '89 Iroc is doing this exact same thing. Any body know if he figured out what the problem was? Mine left me stranded at work and the service station has been trying to figure it out for 2 days and haven't found ****. I am tired of driving this rental Neon and can't afford it to boot.
:hail:
Old Nov 8, 2002 | 04:41 PM
rezinn's Avatar
If your pump is not coming on then you need to trace power and see where it's not making it through. Two things that come to mind are the fuse for the fuel pump, and the relay. The fuse is located near the battery, and the relay should be on the drivers side firewall. You can check for power at the connecter near the differential, and if that doesn't have power(the 2 seconds after you turn the key), trace back farther.
The 'g' terminal on the ALDL is the fuel pump test terminal. Run 12v to this and the pump should run. If not, the wiring between there and the pump is bad, or the pump itself.
All of this only applies if your car cranks, but does not start. If it doesn't crank, you've got other problems.
Old Nov 8, 2002 | 06:03 PM
therym's Avatar
It cranks fine. The shop where I dropped it off keeps telling me it is something in the VATS. I had that happen once but when VATS went out before it wouldn't even crank. They have had it for 2 days and told me it will take them some time to trace it. I don't have gobs of time or money for it. HAving to pay for a rental and then for their 'time' to trace it? If I would have known how long it was going to take them I would have just towed it to my house and tried to figure it out myself.
Old Nov 8, 2002 | 06:54 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
check your fuel pump relay before assuming it's your fuel pump.
Old Nov 11, 2002 | 01:40 PM
therym's Avatar
Shop says it was corrosion on the line from the fuel pump to the VATS. They cleaned the connection and the car started. Guess I'll be tracing down all electrical connections and cleaning the connectors before I get stranded again.
Ghettobird52
Jul 5, 2024 11:18 PM
mhatfield 14
Oct 24, 2015 07:48 AM
nuggie
Aug 25, 2015 01:27 PM
Bob88GTA
Aug 18, 2015 03:31 PM
gta power
Aug 13, 2015 06:15 AM
