Steering box play
Old Aug 10, 2002 | 02:17 AM
jeff85iroc's Avatar
Steering box play
Just a quick question.
Should there be any play at the steering box at all.
Mine has some play and i think it's the cause of my car vibrating it only starts to vibrate at 2500rpm and up.
Could this be the problem.
Jeff.
Old Aug 10, 2002 | 06:04 AM
ede's Avatar
ede
it's normal for a small amount of play to be there and it won't cause a vibration. if it's rpm dependent then it's caused by a miss in the engine and not steering or suspension, like if it was MPH dependent.
Old Aug 10, 2002 | 06:22 AM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Whereas, if it is speed dependent, the first thing I would do is have the front wheels balanced.
Old Aug 10, 2002 | 06:37 AM
jeff85iroc's Avatar
Thanks for the replys.
I will go and get a wheel balance on monday just to find out if that is it,hopefully it will be.
ede what do you mean?Something might not be balanced,crack in flexplate,harmonic balancer.
I go on the freeway every day and this vibration is driving me mad.
Jeff
Old Aug 10, 2002 | 06:53 AM
ede's Avatar
ede
i ithnk you need to restate the problem and when it does it. is it rpm or mph dependent? only does it moving above certin speed or above a certin rpm, you can increase the rpm and keep the speed down by using a lower gear. if it's a mph related problem then check out the front end, rotors for warpage and tire balance. thirdgens also have a history of drive shaft vibrations above 75 mph or so. if you have a vibrations above 2500 rpm sitting still then you have a miss or dropping a cylinder. make sure you have a good tune up and do a compression test.
Old Aug 10, 2002 | 12:01 PM
jeff85iroc's Avatar
ede
It must be mph related because nothing happens when it's reved past 2500rpm standing still.
It only happens on the freeway at higher speeds.
Thanks for the quick reply.
Jeff.
Old Aug 10, 2002 | 02:17 PM
ede's Avatar
ede
if it's speed related check the tire balance, and look for worn suspensio nand steering parts
Old Aug 10, 2002 | 09:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Also bent wheels and separated tires.
Old Aug 10, 2002 | 10:31 PM
86iroctpi's Avatar
Car: 86 IROC
Do you for sure that it is the steering box that has the play in it? My car had play in the steering and I replaced the drag link and outer tie rods and it eliminated all but a very small amount of play in the steering.
Old Aug 11, 2002 | 12:57 AM
jeff85iroc's Avatar
I will get the wheels balanced and suspension checked on monday and hopefully it is the wheel balance.
I'm pretty sure the steering box has play in it 86iroctpi.
Because i hold the cupling that joins the steering shaft to the steering box and it turns about half an inch before the wheels even look like moving. Thanks.
Jeff
Old Aug 11, 2002 | 09:56 AM
Vader's Avatar
Is that with or without the front wheels elevated?
Old Aug 11, 2002 | 08:30 PM
jeff85iroc's Avatar
Vader, thats with the wheels on the ground and when you are driving you can turn the steering wheel a good inch either way before the car reacts.I am only asuming that it is the steering box i hope it's not though.
Jeff.
Old Aug 11, 2002 | 09:43 PM
2vmodular's Avatar
If you end up replacing the steering box, keep in mind that irocs have the "quick ratio" box. Base model f-bodies have a different box that has a different number of lock-lock turns.
Old Aug 14, 2002 | 02:05 AM
jeff85iroc's Avatar
I got the problem fixed today it turned out to be the front wheel bearings.Now no more vibration.
Thanks for the reply's.
Jeff
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Ian Irvine
Sep 4, 2015 08:08 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
