water pump questions
Old Aug 13, 2002 | 02:43 PM
BadMunky87TA's Avatar
im replaceing my water pump, bad bearing or something, squeels alot, anyway, do you have to put any type of sealant on the gaskats? i though i heard no, but i want to make sure, also would it be smart to get the higher flowing w/p from autozone for around $50, or stay with the stock new one i got?
also should i get some new bolts for the w/p because the one that where in there had a rubber type stuff on them but it is kinda ripped in places.
thanks!
Old Aug 13, 2002 | 02:48 PM
TBI305Camaro's Avatar
you dont need to use any type of sealant on the gaskets. I have a cheapo world class replacement pump and it works great. With the new radiator, water pump, and hypertech cool fan switch it runs around 160-170. Car runs real good
Old Aug 13, 2002 | 02:50 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
It's always a good idea to buy some RTV Permatex gasket sealer. For the price only a few $ it's worth the investment.
Old Aug 13, 2002 | 02:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
At least one bolt goes into the water jacket, so you need to use some kind of non-hardening sealant on them. I prefer either Loctite PST pipe thread sealer with Teflon or Permatex 300. I don't use silicone, eventually it always tears and causes leaks, due to the relative motion of the parts with temperature change.
Old Aug 13, 2002 | 02:57 PM
so i can get away with putting none on the gaskets, but i should just in case?
Old Aug 13, 2002 | 05:07 PM
Fast3rdGen's Avatar
use either or but never both
Old Aug 14, 2002 | 01:02 AM
I didnt use anything on the bolts or gasket. I havent had a problem yet.
Old Aug 14, 2002 | 04:12 PM
racerx004's Avatar
It's up to you. Some say you don't need too.
I usually use some sort of RTV or form a gasket just to be safe
because it is a pain to have to take it apart and do it again if it does leak.
You don't need new bolts either. The rubber like stuff on the bolts is probably just the remains of sealant from the last time it was changed. Just clean them up and you should be good to go.
Old Aug 14, 2002 | 04:16 PM
flyway190's Avatar
Permatex makes thermostat housing/water pump gasket sealant. I found it at Pep Boys.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
