question about engine
Old Aug 16, 2002 | 03:04 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
I know that a 350 is a 5.7 engine. But do the engines (350) from different manufacturers have difference in HP? I have a 350 engine and the guy that I bought it from sayes it is out of an Oldsmobile!
Thanks.
Old Aug 16, 2002 | 04:02 AM
Enkil's Avatar
Yes, there are quite a bit of difference in horsepower ratings from different manufactures and years and such. For more info about your engine, what year Oldsmobile did it come out of?
Old Aug 16, 2002 | 06:13 AM
ede's Avatar
ede
at one time bop and chevy all had 350s and they weren't very similar or interchangable.
Old Aug 16, 2002 | 07:57 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
Thanks for your replyes. I called the guy I bought the car from but he also knows that it is just an olds engine and thats it. Can I identify it buy the serial number? If so where can I find them. Are the numbers on the same place as the chevy engine or somewher else?
Old Aug 16, 2002 | 08:27 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Some Olds cars came with Chevy engines, and some came with Buicks, besides Olds motors.
Let's see... a few things to identify one with...
If it's a Chevy, the water pump will be on 2 legs sticking out in front of a sheet metal timing cover; if it's Olds or Buick the water pump is a flat cast aluminum piece that covers the front of a cast aluminum timing cover. If it's not a Chevy, a Buick has the oil pump in the timing cover, it's a piece of sheet steel covering over a projection down low ont he pass side; an Olds doesn't have that.
Old Aug 16, 2002 | 08:58 AM
9225th's Avatar
Oldsmobile engines have the oil filler in the front, right in the center.
Jeff
Old Aug 16, 2002 | 09:40 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
Yep the oil filler is in front and in the middle. The only numbers I found from the engine were 411 829. And they were on the side of the engin. Anybody have any idea what they mean?
Old Aug 16, 2002 | 10:10 AM
9225th's Avatar
Some of the Oldsmobile engines have the cubic inches stamped on the side of the block. It would have something like 260, 307, 350, 403 etc.....
Hope this helps
Jeff
Old Aug 16, 2002 | 10:26 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
Are you telling me that I could have 411 cubic inch engine, if there eaven is such a thing? That would be something interresting!:lala:
Any other way I could figure out what I have?
Now I really need help!!!
Old Aug 17, 2002 | 01:33 PM
9225th's Avatar
No! I said some of the Olds engines had the CID stamped on the side of the engine. Actually it is raised numbers. Is the motor blue or gold?
Jeff
Old Aug 19, 2002 | 04:01 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
Yes the letters are raised. The engine is blue.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
