alternate crankshafts
Old Aug 24, 2002 | 09:33 PM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
what crankshafts will fit into a 350 with minimal fitting? specifically something with a shorter stroke. Just brainstorming here. Thanks
Ryan
Old Aug 25, 2002 | 01:21 AM
ede's Avatar
ede
if you go shorter they'll all fit with no extra work, clearancing or problems. why would you want to do something like that? as rb says you'd be spending you time and money on bullets to shoot yourself i nthe foot with.
Old Aug 25, 2002 | 04:24 AM
alohamike's Avatar
If you have the newer one piece rear main, you'll want to have the one used in the small V8 they put in the Caprices in the mid-90s. believe that's a 3.25 inch stroke but whatever it is, you can use that to make a 302. What are you thinking of building?
Old Aug 25, 2002 | 10:19 AM
I was thinking of building a turbo or super engine with a stealth ram or mini ram intake. there was a discussion on the power adder board of how ci doesn't help for overall horsepower with a blower application, just low end torque. with a shorter stroke engine, I'd be able to get better top-end power and higher max rpm.
Old Aug 25, 2002 | 10:32 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
A 350's 4.00" bore and a 3.25" stroke make 327 cid not 302 cid. A 302 would have a 3.00" stroke.
Old Aug 25, 2002 | 10:40 AM
ede's Avatar
ede
i believe reguardless of application, power adder or NA more inches make more power, all else being equal.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
