Best cam for a 350 sbc
Old Aug 28, 2002 | 07:26 PM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
Transmission: 700R-4
I am building a 350 and I want an aftermarket cam. I want a cam with power all the way through the powerband or at least at low rpm's. The motor is also out of an 88 IROC and is going to be carbed. Thanks!
Steve
Old Aug 28, 2002 | 07:31 PM
alohamike's Avatar
LT4.
Old Aug 28, 2002 | 07:38 PM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
LT4 cam????? Where can I find one of those? How much do they run? Thanks!
Steve
Old Aug 28, 2002 | 08:32 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Comp 268XE, I love mine.
.477/.480 lift.
Old Aug 28, 2002 | 09:21 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Get a dual pattern lift cam. This will give you a slightly broader power range. If your wanting to get decent high end but keep a nice amount of vacuum and torque then stay around a 450-460 lift with about 224 duration (at .050), about 112-114 lobe sep. This will give you a range from 2000-5000 depending on what the other components are (intake, heads, compression, etc). Mark, how did the cam swap go?!! Hows the power difference? BTW- I finally got the car down to a 9.1 at 77mph. That was with a intake manifold leak and a huge header leak. The car is down right now though .
Old Aug 28, 2002 | 09:35 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
depends on what else you are putting into the motor as far as heads, displacement and bore and stroke...
what else do you have planned
ppl can say this cam would work great for your car
but then they find out your building a car with huge intake and exhusat ports that would move the powerband above the range of the cam you might lose power
Old Aug 28, 2002 | 09:46 PM
Car: 99 Formula
Axle/Gears: 342
Very good point. Also gears and TC matter too.
Old Aug 29, 2002 | 11:48 AM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
Well, I'm not going to get too crazy with it. I am swapping a Holley 600 carb as well as an Edelbrock Performer Intake on it that I have from my 305. I also have so no-name headers that I'm sticking on there. I'm gonna stay with stock L98 heads right now (I have school to pay for). I also have 4.10 gears. I should really make a sig. Lol. Hope this helps!
Steve
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
theshackle
Aug 22, 2015 06:52 PM
86iroc z Z28
Aug 21, 2015 10:37 PM
theurge
Aug 21, 2015 12:46 PM
