Can I use ATF in my PS?
Car: 99 Formula
Axle/Gears: 342
Aren't they basically the same. I don't have any PS fluid here but I have some ATF...
Car: 99 Formula
Axle/Gears: 342
Originally posted by brodyscamaro
they look and smell the same so go ahead...
Car: '94 Corvette
My mechanicly challenged brother ounced put ATF in the brake reservoir. The only words from my mouth were: "So, how much did they charge to flush, & replace all the seals?"
Ron
Ron
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I always use ATF for power steering fluid and I have never ran into any problems. Don't use brake fluid though, because brake fluid will not withstand high temperatures like ATF will, and it also does not lubricate as well. I wouldnt use Type F fluid however, because it is known to eat through rubber, and we have rubber PS lines, and rubber seals in the steering box.
