Need some opinions on what kinda large capacity oil pans everyone is using
Old Sep 12, 2002 | 01:40 AM
89ProchargedROC's Avatar
Well?
I have to run a high volume pump for my setup and dont ask what kinda setup cuz i aint telln'.....yet
Just trust me on it
With the high volume pump i do need a larger pan and was curious as to what people use and have good success with
Also...i'm not running a y-pipe so i'm not concerned with the room where the crossover would go
thank you
Old Sep 12, 2002 | 07:09 AM
scauffiel's Avatar
I'm running a Moroso 7 quart pan with no real issues - other than only having five inches to the deck...
S.
Old Sep 12, 2002 | 08:35 AM
What do you mean by "only having 5inches to the deck"?
Old Sep 12, 2002 | 01:05 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Moroso 7 quart (#20180) here...no clearance issues.He probably means 5" of ground clearance since it hangs lower than the stock pan.
Old Sep 12, 2002 | 02:04 PM
Brian'sIROC's Avatar
I'm running the Milodon 7qt. (30902) There are some y-pipe clearance issues.
Old Sep 12, 2002 | 08:12 PM
That comes up as a 6 quart pan
Old Sep 12, 2002 | 08:14 PM
i have a driver side dipstick
Old Sep 12, 2002 | 08:20 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
7 quart if you add one for the filter...but yes 6 quart pan.Still big enough for even the wildest small block that will fit in our stock chassis.
Old Sep 12, 2002 | 10:19 PM
You could put me in that "wild" category
Hopefully the car will be up and operation second week of october
Old Sep 12, 2002 | 10:20 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I bought Summits version of the Moroso pan for $75.00, holds 6 quarts also. I had a hellava time gettin the motor in as the squared bottom of the pan, accomponied by the short cherry picker arm and long snout on my firebird trying to get it past the crossmember and brake lines. I installed new motor and tranny as a unit so had more clearance issuses to contend with also.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Blue419
Sep 10, 2015 01:03 PM
carattini
Sep 10, 2015 07:46 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
