Dont use fron/rear intake gaskets on LG4??
Old Sep 17, 2002 | 07:29 PM
LarsZ28's Avatar
My felpro gasket kit didnt come with front and rear intake manifold gaskets, it says to just use RTV??? Does this sound right????
Old Sep 17, 2002 | 07:32 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Hmm, on my LG4 intake I used those gaskets, and some RTV, but not sure if the block plays a more important role in that. This was on my new 350.
Old Sep 17, 2002 | 07:37 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
It's because those things are garbage. I used them once on my brothers 305 and within a day we had oil leaks. Removed those peices of trash and never had a leak after that. Since that day, I've never used them and never had a leak, at least not there.
Old Sep 17, 2002 | 07:41 PM
LarsZ28's Avatar
CraZ-28, So you just used RTV??
Old Sep 17, 2002 | 07:43 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Yep, use the RTV. Forget abt the gaskets.
Old Sep 17, 2002 | 08:16 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I don't know why them even make the rubber gaskets anymore, it's common practice to throw them in the trash, when ya use the RTV, I personally use black, but other's I know had luck with the red also. I run a tiny bead around the water jacket on my heads, press the intake gasket into place, the rtv helps hold it and makes sure it seals better. then run another tiny bead around the water jacket on the intake gasket itself, then lay a good 1/4" tall bead starting about a 1/2" up on the intake gasket then across the front of the block and up 1/2" onto the other side intake gasket. Same for the rear. You might say the water jacket use is overkill, but it's never failed me yet, helps with installation, and doesn't hurt a thing.
Old Sep 17, 2002 | 08:25 PM
LarsZ28's Avatar
Thanks a lot guys, I feel better now
Old Sep 17, 2002 | 08:54 PM
rezinn's Avatar
Agreed. I have about six of those gaskets(except mine were cork) stuck to my garage door. RTV has always worked fine for me.
Old Sep 17, 2002 | 09:17 PM
ede's Avatar
ede
i use the china wall gaskets if the engine is on a stand i can see and handle the intake with no problems. if the engine is in the car or truck i use ultracopper, either way the last time i had one leak was in 1977 and left me stranded 40 miles from home.
Old Sep 17, 2002 | 09:48 PM
IHI's Avatar
IHI
ede were the gaskets the ones with lips on both sides to hug the block or did they have the dicks that stuck down into the holes in the block, I've heard the dicky ones work pretty well, but the huggers not worth a ****.
Old Sep 17, 2002 | 10:19 PM
laiky's Avatar
i would reccomend "GREAT STUFF" silicone, best i've ever used. 1/4" bead is just right, fit your manifold on the gaskets first incase some thing is causing a bigger space. then lay the bead down, give it 5 minits then driop the manifold on, strait down though dont slide it around. Also in the event your a really fast manifold installer, i would make sure it has time to dry before starting the car.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
