Gas in oil
Old Sep 18, 2002 | 06:47 PM
Duke901's Avatar
Car: 89 Formula
Gas in oil
I have the chance to buy a 1985 TA with TPI for real cheap, but the car dont run the guy said that he drove it for a year and then for 3 days it ran really bad but it didnt throw a code. Then one day he tried to start it and it only turns over but will not fire, and now when you pull out the oil dip stick it smells like gas. So what could be wrong with it. iam hoping its not a cracked block.
THANKS
MIKE
Old Sep 18, 2002 | 06:59 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
It could be a spark plug is not firing and gas is poring into the cylinders and seeping in to the oil pan.
Old Sep 19, 2002 | 08:55 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Hm. How cheap?
Old Sep 19, 2002 | 09:12 AM
Duke901's Avatar
Car: 89 Formula
$500 the body is good, the floor is solid, the interior is also good.
Old Sep 19, 2002 | 08:37 PM
Duke901's Avatar
Car: 89 Formula
So is the gas in the oil really serious or
Old Sep 19, 2002 | 09:00 PM
evil t/a's Avatar
Most likely it is a leaky injector or a few of them.
Old Sep 19, 2002 | 09:09 PM
Duke901's Avatar
Car: 89 Formula
Ya but would bad injectors cause it to run bad for like 3 days and then not run at all a day later.
Old Sep 19, 2002 | 09:11 PM
CamaroDriver's Avatar
Could be a PCV valve.
Old Sep 19, 2002 | 09:17 PM
evil t/a's Avatar
Yep , leaking enough to make it run really rich and then leaking enough to flood a cylinder.
Old Sep 19, 2002 | 09:22 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Pull all the plugs out, take the 12v wire off the dist. and crank the hell out of it. If a cylinder, or cylinders have excess fuel, this will blow it out. Clean off the plugs, check the gap, put everything back and see if it will fire. And yes, gas in the oil is bad. One reason is because it is not suppose to be there. If the the oil gets thin enough, the bearings will let go.
Old Sep 19, 2002 | 09:28 PM
Duke901's Avatar
Car: 89 Formula
Would leaky fuel injectors cause the car to stop running like that. Cuz the guy iam going to buy the car off of said he drove it for a year and like for 3 days straight it ran really bad and then one day he went to start it and it would only turn over but wouldn't fire. And then he pulled out the oil dipstick and it smells like gas. So could it be the bad injectors or maybe the timing chain is bad or something else.
THANKS
MIKE
Old Sep 19, 2002 | 09:35 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
Change the oil, take out the plugs, turn the motor over like it has been said. A plug that is wet will not fire. By the car none the less. 500 for car like that is well worth it. How many miles? But give this a try, good luck.
Old Sep 19, 2002 | 09:42 PM
Duke901's Avatar
Car: 89 Formula
It has about 115,000 miles. the guy also said that it didnt throw any codes so iam just trying to find the problem.
Old Sep 19, 2002 | 10:35 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
it's simple either on of the 8 injectors is leaking badly/stuck open, the cold start injector is leaking, or the fuel pressure regulator has ruptured. be sure to check for spark and ignition components as previously metioned. all in all it should be a some what simple fix. atleast to me it is.
Old Sep 19, 2002 | 10:46 PM
Duke901's Avatar
Car: 89 Formula
Ok thank you, with anyone of those being the problem would they throw a code or not.
THANKS
Old Sep 19, 2002 | 10:50 PM
Car: 1988 IROC-Z
no code for the above listed. they are mechanical problems. (things the computer can't really monitor)
1992 Trans Am
May 10, 2023 07:19 PM
Derick15
Sep 17, 2016 05:28 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
