Gas Tank Replacement..NEED HELP ASAP
Old Sep 19, 2002 | 04:13 PM
2xsess's Avatar
I got the old one out and the new one ready to go in , what do I do about the strips across the top of the old one, they're like deadening material or what??!?!? Should I put the new one in without them? I can't reuse the old ones....
Also, the white wire at the fuel pump was bare about a 1/4" back from the connector, is the normal? I know it was like that.
Please help, I need to get this done before it gets dark out!
Thank you,
Old Sep 19, 2002 | 04:21 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I wouldn't install it without the rubber material. It will make alot of noise if you don't have that stuff. I don't know what else it might be for but that is probably the main reason. As far as the wire I don't know.
Old Sep 19, 2002 | 04:26 PM
2xsess's Avatar
Thanks, I just talked to one guy and he said the strips are a spark inhibitor. sounds logical to me.
Old Sep 19, 2002 | 09:15 PM
2xsess's Avatar
Well, 87WS6 I thank you for your help, sincerely.
The tank is in, if anyone happens to read this post, please let me know if that bare wire is normal.
Thanks,
Jeff
Old Sep 20, 2002 | 12:58 AM
Morley's Avatar
Thanks,
Jeff
Not normal, sounds like the insulation may have shrunk back, try putting some heat shrink on it.
Old Sep 20, 2002 | 02:12 AM
90FirebirdV6's Avatar
i would use some shrink tubnig also, or electrical tape to cover any exposed wire, and for the rubber its a anti-squeak pad so when your driving the tank moving around it doesnt make much noise.
Old Sep 20, 2002 | 09:16 AM
2xsess's Avatar
Well, it's in and I'm assuming it's been like that. I really don't want to have to pull that back down.
Here's a pic of the wire.
Old Sep 20, 2002 | 09:31 AM
89ProchargedROC's Avatar
LOL....
thats the power wire to your fuel pump
if you start to have issues with your car you cant figure out......thats the first place i'd look
have fun
Old Sep 20, 2002 | 09:33 AM
2xsess's Avatar
Originally posted by 89ProchargedROC
LOL....
have fun
Issues like?
Old Sep 20, 2002 | 10:10 AM
car bogging
hesitation
fuel pressure fluctuations
car just not running right.....
with a bare wire like that and hitting bumps in the rode eventually it is going to fray out completely and you are going to have to fix it.
you also may not be getting full voltage to the pump with a wire that like which will cut down on how much fuel your pump flows
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Bohemian
Aug 15, 2017 05:11 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
