things to look for when buying a 92 T/A?
Old Sep 20, 2002 | 12:54 AM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
I just wanted to know what to look for when purchasing a 92 T/A. So if you guys know anything I should keep my eye out on so I don't buy something thats going to need alot of work, then I would really apriciate your info.
Old Sep 20, 2002 | 01:07 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Personally I'd make sure to get a TPI engine. Stay away from TBI. They don't have carbs in that year model so be glad for that. The TPI's have more stock HP then the TBI's do. And they are more reliable. As far as the rest of it goes the options are all up to you. It depends on what you want. If you like T-Tops and so fourth If you do like t-tops I'll give you one piece of advice. Do *NOT* get the plastic ones. Only get the glass ones. The Plastic ones look cheap and they bubble/dome out. I have heard they leak more also. If you want alot of other options like leather and power seats and what not look for a Trans-AM GTA. But expect to spend alot on it. GTA's above 1990 still cost quite a bit.
Old Sep 20, 2002 | 01:17 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Like said, I wouldn't get a TBI one, look for TPI, 350 TPI if you're more concerned with speed.
Old Sep 20, 2002 | 02:39 PM
92Transam's Avatar
yea im planing on getting a 350 TPI with glass t tops, I guess I should have stated that first.
Old Sep 20, 2002 | 02:50 PM
CamaroFreak406's Avatar
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
Mark, I'm surprised at you. There was no TBI T/A in '92, they were all TPI.:nono: .
Later, and Good Luck, Garrett
Old Sep 20, 2002 | 04:19 PM
Car: 99 Formula
Axle/Gears: 342
yeah, I don't follow the history of birds too much.
Old Sep 21, 2002 | 06:05 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
There's also no factory T-top 350 cars for '91-'92. '92 T/A's and GTA are both quite rare. There was something like only 1100 T/A's and 228 GTA's. I am sure someone from the History board can attest to that. It's a lot easier finding the '91's for sale.
Old Sep 21, 2002 | 11:34 PM
wes2k3's Avatar
There were 350 T tops formulas. If I am not mistaken all 305 GTAs were 5 speed. Good luck
Old Sep 22, 2002 | 02:13 AM
Jade Grey's Avatar
Engine: 305TPI
I stand corrected. I never knew that there were T-top 350 Formulas in '92. I found mention of it on the GTA source page.
Beginning in 1991, no Firebird with the L98 motor could be equipped with the T-Top roof (except for the 1992 Formula with the 16' x 8" PW7 diamond-spoke wheels........?), so only the 5.0L GTAs could have them installed.
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
Bob88GTA
Aug 18, 2015 03:31 PM
86White_T/A305
Aug 17, 2015 12:16 AM
