throwing belts
Old Sep 25, 2002 | 03:18 PM
82z28122's Avatar
throwing belts
My car is an 82 z28. The motor is not the 82 but a 68 350, but I do not know what it is out of. Here is the problem. It will not quit throwing the water pump, alternator pulley. I s there a serpentine belt system I can buy for my car, and It does it usually when you floor it. thanks.
Old Sep 25, 2002 | 03:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That is usually a lineup issue...
Which belt system is it? (left-hand alt, right-hand alt)
Old Sep 25, 2002 | 06:47 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
Mine was doing the same thing this weekend. I had just switched the belt. I tightened the alt. adjustment bolt up too much and it started to pull the threads out. SO it felt tight to me when I put it on, but when I gunned it it would have enough torq to loosen it up then throw the belt. I took the same size bolt, only just got a longer one and put it all the way throught the casing and put a nut on the other end. I havn't thrown a belt since then, so that was my problem. Make sure you didn't tighten that bolt up to tight and pull the threads out.
Old Sep 25, 2002 | 06:55 PM
82z28122's Avatar
the alternator is on the passenger side. Would a serpentine conversion be worth it, and how can I fix the alignment problem. The belt isnt loosening it is twisying, so it must be an alignment issue.
Old Sep 25, 2002 | 06:58 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
SHoudn't you be able to look at it and see it is out of line.
Old Sep 25, 2002 | 07:01 PM
82z28122's Avatar
it is not that out of line. It only does it when the car is floored usually, and it must be only slightly off.I will just have estimate how far it is off. would a serpentine conversion fix this though
? thanks
Old Sep 25, 2002 | 07:12 PM
ronterry's Avatar
Car: '94 Corvette
Had the same problem!!!
I bought a set of March Performance serpentine pulleys for 200 umpteen dollars.
The alignment is perfect! & the pulleys are 6 ribs.
Summit Racing Price:
MCH-6380 High water flow/Long water pump $191.95
MCH-624 Matching Power Steering Pulley $72.39
Ron
bad84z's Avatar
Car: 84 Z28
Engine: 355
I don't know, but it sounds like it would be harder than just fixing your alignment problem. Sounds like you have a bracket problem if it only does it when you floor it.
Old Sep 25, 2002 | 07:15 PM
82z28122's Avatar
it possibly could be a bracket problem because our stock alternator bracket will work with my intake so does anyone make one for my intake?
Old Sep 25, 2002 | 07:41 PM
82z28122's Avatar
ronterry did you get the brackets with those too, because I like the alternator bracket.
Old Sep 25, 2002 | 07:54 PM
ronterry's Avatar
Car: '94 Corvette
I had it before I bought the pulleys, but March does sales a full kit with all the pulleys, alt braket, & power steering bracket. I think it was $499 or something though
The braket is a March Performach alternator braket, and I think it set me back like $60 bucks.
March stuff is pricey, but most people here will agree that it's quality stuff.
BTW: before I did anything to my old pulleys, I used water pump pulleys shims, and washers to get my old pulleys to line up. It wasn't till I starter pushing >6000rpms that my damn alt belt would wrap up on my water pump, and I was at risk of destoying a very expensive race motor, and aluminum water pump. That's when I put up the money for new pulleys!!!
Ron
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
racereese
Oct 3, 2015 03:46 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
ndndndnd
Sep 28, 2015 08:00 AM
kitt23
Sep 26, 2015 07:48 PM
