can i trust an old engine?
Old Sep 26, 2002 | 09:42 PM
mikyg's Avatar
87 t/a got 160,000 miles, if tuneup can i rely on this car to bring me over 100 miles a day back and forth from work each day?
Old Sep 26, 2002 | 09:45 PM
92 Red Firebird's Avatar
it depends on how the car was treated. if it was it abused then no. otherwise i've seen people with over 200K on thirdgens and still tickin.
Old Sep 27, 2002 | 06:00 AM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
i drove a grand voyager to work 80 miles everyday during thw inter. car had 250k and hadnt had an oil change sicne prob 190k. i think if i can do it in that pos if you care for yours you should have no problems
Old Sep 27, 2002 | 08:41 AM
Vader's Avatar
305 or 350? The 305s tend to be slightly more durable, if for no other reason than the bore/stroke ratio tends to ease the side load on pistons, and the bottom ends face a little less stress.
Either way, Red nailed it. Depending on how it was cared for, you can determine the reliability. I'd suggest a fairly thorough diagnostic, including cylinder leakage test, oil pressure at RPM via a separate mechanical gauge instead of the dash instrument, and an oil analysis. Obviously, anyn indication of a problem would require your attention. And don't overlook the trtansmission and axle.
After that, freshen all the fluids with synthetics if you want maximum wear resistance and reliability, not to mention better fuel efficiency and power output.
Old Sep 27, 2002 | 02:04 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
My camaro had 150k miles on it when I was running low 15's with it, then I felt comfortable enough selling it to my good freinds sister. Oh yeah, and I drive an '89 C1500 pickup to and from school with a 350 that has over 202,000 miles. You can't expect to get a th700 to last as long though, seems to be the weak link in the drivetrain. Like everyone else is saying, it really depends on how these things are taken care of.
Old Sep 27, 2002 | 08:07 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
My GTA was a 1-owner car when i bought and it was well taken care of. Its been one of the most reliable cars i've had. It has 110000 miles on it.
Old Sep 28, 2002 | 01:02 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
My thoughts are "Weak-*** motors never die"
My 2.8 is 160,000 and never had the valve covers off. Puff's (Valve seals) at cold startup but runs like a champ. Never touched the tranny or rear as well. Just an oil change every 3000 and tuneups and the usual (Water pump, alternators, starters, modules.....) every so often.
Never left me stranded though.
Old Sep 28, 2002 | 11:41 AM
cdogc350's Avatar
2.8....GM did a very good job an that gen. engine. the 2.8 and 3.1 versions of it. its absolutely indestructable. ive had many friends with it who have beat the HELL out of it and it runs like a dream. My girlfriend has a 2.8 in her 88 olds cutlass and i beat on that thing when i drive it. its run on WAY overdue tuneups perfectly. I change the oil every 2500.but once i let it run till 6500..and the oil came out amber..not like the dark chocholate a 160,000 mile engine usually does. I hate when people say hondas are reliable....when i use to work in the independant shops, the imports seemed to have more internal engine probs than the domestic. You let an jap motor go overdue on a tuneup......doesnt last too long
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Bryan F
Aug 18, 2015 02:28 PM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
