car shuts off when stopped
Subscribe
Sep 28, 2002 | 12:11 PM
NOt everytime but very frequently when I come to a stop sign of a light. My engine dies down and cuts off. Its and 88 305 Iroc.
It happens more often when I got the A/C. I was wondering if ayone else experienced this and what could I do. this has been hapening since I bought the car in Jan. Ive only changed/added
K&N
MAF
Oxygen Sensor
Feul Pump
Heater Valve
Thanks for any help
Reply 0
Sep 28, 2002 | 12:53 PM
Clean the throttle body and IAC port with carb cleaner. You will have to do this at least once a year, but I do mine 2 or 3 times and it always seems to be dirty.
Reply 0
Sep 28, 2002 | 01:08 PM
I would check either your distributor and rotor, or have your alternator checked out.
I had a car doing the same thing, and it was my points; grant it, that car was 28 years old too. But when I did buy my current Camaro, the rotor and cap looked like sh*t. All the points where worn down or chipped. And the metal piece on my rotor, just fell off when I took it off.
Reply 0
Sep 28, 2002 | 01:45 PM
How would I go about cleaning the throttle body and IAC. Plaese be sorta specific I'm not familiar with all the parts. and I dont wanna damage anything important. Thank you for your help
Ps you think you could hook me up on some of those "Free Mods" cause I'm kinda broke
Reply 0
Sep 28, 2002 | 06:37 PM
Yea I would like to know how to properly clean the IAC port and throttle body as well. I'm always afraid of screwing something up.
There are some easy free mods to do. You can open the air box on your car, do a throttle body bypass, or put some K&N filters in.
Reply 0
Sep 30, 2002 | 11:36 PM
Check out Vader's response in the "Here's a Wierd Problem" in the Tech/General Engine posts. Everything you ever wanted or didn't want to know he covered. A while back he responded to my post on a similar problem and it worked for me.
Reply 0
Oct 1, 2002 | 12:17 AM
Does it die immediately when you stop, or does it bog a bit first after you've stopped? If engine RPM decreases as your speed decreases, you might have a problem with your torque converter lock-up.
If it's something that is much less consistant, and doesn't do it everytime you stop, it might be your ignition pick-up coil. Of course, once the car dies, it's usually hard to get it started again. - John '89 L98
Reply 0
Subscribe
