Is this a 'vette motor??
Car: 1990 Camaro Iroc-Z Convertible
Transmission: Automatic
I'm considering my options as far as a crate motor vs rebuilding what I have. I think this may be a vette L98, but the price seems to good to be so. Regardless, this vendor seems to have good prices. Can anyone tell me if this is a L98 vette motor??
http://www.rebuilt-auto-engines.com/...27102519540.17
Originally posted by vortechLT1
the vette had a 4bolt main
What gets me is those heads look like L31/LT1 heads. It also says SFI at the top, but nothing from 87-92 had SFI.
ok you are right! my 95 LT1 has those same numbers on the heads and the block but mine is a 4bolt main, I know for a fact the LT1 from the vette had a 4bolt and the Fbody had a 2bolt but was not positive on the L98
From: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
The L98 from the vette was a two bolt also. I swapped one into my last GTA. Had to change the pan for the swap.
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Some Vette L98s had 4 bolts but I can't remember what the deal was with how some got them and some didn't, but I have seen them in 2 and 4 bolt main versions.
Car: '87 Camaro LT
Engine: 355 L98
i have a vette l98 and also had to change the oil pan, the sump is too long. also you'll need to get a camaro oil pickup and not vette cuz the bend in the tube is sharper in the camaro one to clear the shorter sump. damn, i paid a grand for mine with 100k on it, wish i'd seen that before. i ended up parting the tpi out and got $400 back.
