What does resurfacing heads mean?
Old Sep 29, 2002 | 11:31 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Like the topic says, also, is it recommended on used heads. I can get it done for $20.
Old Sep 29, 2002 | 11:59 AM
sleeper's Avatar
Resurfacing is grinding a few tens off the bottom of the head to make it flat again.
When you resurface you change the head to intake angle and increase the engines compression (depends on how much you shave).
Old Sep 29, 2002 | 12:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It should always be done to used heads of unknown origin, or ones where a head gasket has blown, or when there's visible damage. It's a generally good idea to shave a couple of thousandths off of any heads just to be sire they're true.
Old Sep 29, 2002 | 12:19 PM
Car: 99 Formula
Axle/Gears: 342
Thanks, would I need the intake resurfaced then to match up?
Old Sep 29, 2002 | 12:22 PM
sleeper's Avatar
good idea... they can also shave the intake to get the angle right again (after the heads/block are done)
Old Sep 29, 2002 | 12:34 PM
Guest
Guest
Posts: n/a
You could, but unless there is a bunch taken off the heads, its not necessary.
Old Sep 29, 2002 | 03:02 PM
Car: 99 Formula
Axle/Gears: 342
OK, thanks.
Old Sep 29, 2002 | 03:41 PM
ede's Avatar
ede
it's done on a big belt sander, more or less. if i remember right my shop can only remove .010 at most so if the warp is more than that it would need milled. usually it's only a few .001s that's removed. if i have block at the shop i have it resurfaced and the heads but i never take heads to the shop, unless they need surfaced.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
