alright figured out what cam but..
Old Sep 30, 2002 | 01:16 PM
no_car_yet's Avatar
i can't find how to order it. i want the compcam xr264hr-10. here is a page i found on compcams website
http://www.compcams.com/information/Search/CamResults.asp?Known=xr264hr-10
but i am not sure what is better. and i how do i order it? i want the xtreme energy 264 hydralic roller. Will i need to buy anything else besides the cam for the installation? thanks guys!
It does has a 110 lobe separation, which is more computer friendly.
I'd just like to add a thanks to you guys for helping me pick out this one, because when i first started looking for one i had no idea about lift or anythiing like that...especially LC1500, you've been a great help.
Old Sep 30, 2002 | 01:26 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Call Summit and tell them what you want. They'll have the part #.
Old Sep 30, 2002 | 02:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If this is going in the 91 in your sig, the Summit # will be something like CCA-08-412-8
You should definitely absolutely put new valve springs and all their hardware on it, and consider a timing chain and a set of better rockers.
And of course you'll need intake and valve cover gaskets, misc TPI gaskets, fluids & filters, vacuum hose to replace the dried up brittle ones that will surely break, etc.
Old Sep 30, 2002 | 02:28 PM
Car: 99 Formula
Axle/Gears: 342
You forgot water pump and dist. gasket. Though I found that fel pro intake gaskets come with a dist. gasket.
Old Sep 30, 2002 | 02:36 PM
jimmy_mac's Avatar
You might want to check out this part # at summit CCA-08-302-8. It probably pretty close to the specs you where looking at but made specifically for computer controlled motors. I think the only difference is it has 112 degree lobe seperation. Not sure if it will make a huge difference to gain that little bit of vacuum but you gotta figure comp cams has to have a reason for doing it.
The reccomended springs are also listed for that cam and are reasonably priced.
Old Sep 30, 2002 | 03:59 PM
no_car_yet's Avatar
alrighty then, yes it is for the 91 in my sig. does summit have a website? minus the price of the cam itself, what will the rest of the stuff cost including new springs and maybe rockers?
Old Sep 30, 2002 | 04:14 PM
no_car_yet's Avatar
alright, just check the price of the cam and all the recommended stuff and it comess to about 630 plus tax just for the stuff. Now i am prob gonna need more stuff(IE gaskets, which i don' think are tooooooooo much) plus thecost of all the porting i am doing. now i am not rich so this just went from a right away thing to order what i can afford and keep it all until i got everything then put it all in. I'll have it done by the srping anyway...because up here in canada.....my car went into storage already!
Anyway i am more confident about these parts because they are all for my exact location and have pretty good cam specs, so this is what i am getting....
ONCE AGAIN, THANKS ALOT GUYS!
1986Z28OWNER
Dec 13, 2015 10:19 PM
509 camaro fan
Sep 6, 2015 10:43 AM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
michealleger
Aug 26, 2015 03:29 PM
Fronzizzle
Aug 9, 2015 01:15 PM
