starter removal
Old Oct 6, 2002 | 01:52 PM
ajschillaci's Avatar
starter removal
Ok what is the trick to getting the starter off of the car? I have removed all bolts and wires to the starter but now can not get it out from under the car. Help
Old Oct 6, 2002 | 02:50 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
do you have a v8 or a 6? i have to unbolt my exhaust system to let the starter drop down on my car.
Old Oct 6, 2002 | 03:22 PM
RageSK813's Avatar
I have a V6 and i just replaced mine yesterday. All i did was pull on it some to get it out then it slide out over the muffler pipe. It was just the right amount of space for it to come out.
Old Oct 6, 2002 | 04:05 PM
TBI305Camaro's Avatar
youll probably have to move the exhaust. What I did the first time was actually take the starter apart while it was up in the car and let it fall...I was hoping i could get it in without dropping the exhaust but i couldnt.
Old Oct 6, 2002 | 05:46 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
This was the first thing I had to do on my 87 TA. I have a V8, so if you do too, this will be helpful. Im assuming the starter is a stock starter.. All you have to do is removed those three bolts holding the solenoid onto the motor. There isnt much in there, just a spring inbetween. i didnt want to mess with my exhaust...the bolts were all rusty and I wasnt about to have breaking problems. It was easy. Take the new starter apart the same way, stick the big part up first, then assemble the solenoid when its up there. It takes alittle patience, and alot of if you have to do without seeing, but I thought it was really easy. You dont mess anything up by takin it apart. Just a suggestion. If you mess the starter up, chances are you can take it back or something....if you screw your exhaust up, you are...well, screwed. Hope that helps. OH YEAH....dont forget to measure and use the shims if you need em...I forgot to put those on and almost ruined the new motor. Good luck!
Justin
Old Oct 6, 2002 | 09:26 PM
SgtSkip's Avatar
I drop my "Y" pipe off of my exhaust mainfolds and then the starter drops right out. Takes a total of about 5 min to do...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
383cam
Sep 9, 2015 06:01 AM
Stryker412
Sep 7, 2015 09:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
