Over-Heating Prob.
Old Oct 7, 2002 | 10:40 PM
camarochic's Avatar
Car: 86 Camaro Iroc-z, 86 Corvette
Engine: 350 TPI Camaro, 350 tpi Corvette
Over-Heating Prob.
I have an 1986 iroc-z TPI. When I turn on my ac the car will start to over heat horribly, and it trips the service engine light. Then if I turn on the heat first it will just trip the service engine light, But the car will still over heat . But if i had the ac on and just befor the car starts to over heat , I put on the heat . And it will just trip the service Engine light and not over heat, And I will loose power. What should I do to stop This from happening?? Thanks!! :lala: :lala:
Old Oct 7, 2002 | 11:47 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
I think you'd get more answers on the cooling board, but...
1. Make sure you have the air dam underneath the nose
2. Make sure your radiator hoses aren't collapsing
3. Clean the radiator of all bugs and other crap
4. Check your thermostat
5. Check your coolant sensor
6. Make sure your coolant/water ratio is right and that you have enough fluid
And if all else fails, just screw it and don't use the a/c! lol
Old Oct 8, 2002 | 09:45 AM
Vader's Avatar
What error codes are you generating? It's easy to find out with no more tools than a paper clip and your ignition key.
Free Bird
Jan 30, 2002 11:02 AM
hot86z-28
Theoretical and Street Racing
Jan 3, 2002 05:16 AM
lilley76
Oct 23, 2001 03:00 PM
grafix
Jul 14, 2001 09:24 PM
george ostrom
Oct 15, 2000 04:43 PM
