How much would you pay for aluminum heads?
Old Oct 9, 2002 | 04:50 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'm specifically talking about the vette heads. I realize these aren't the best flowing head, so I realize at some pt, the cost effectiveness of it will dwindle.
So, how much would you pay for a set of these, considering there are no problems with them?
Old Oct 9, 2002 | 05:04 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I got my set used for $400 complete with rocker arms. The set you posted earlier look pretty good, just need a clean up. I don't think I'd pay any more than what I payed.
Old Oct 9, 2002 | 05:06 PM
Car: 99 Formula
Axle/Gears: 342
Thanks for the info.
Old Oct 9, 2002 | 11:54 PM
iroc22's Avatar
I've found around here that they're worth a million dollars because they came from a Vette.
Old Oct 10, 2002 | 12:04 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I bought a set off a zz3 for $500 and they only had 3000 miles on them.
Old Oct 10, 2002 | 12:50 AM
ZZsmpch's Avatar
Yeah, no more than 450-500. They are decent heads with some porting.
Old Oct 10, 2002 | 10:19 PM
86IROC350NY's Avatar
Vette heads are good with porting
An 89 350 forlula got into the 12s with the SLP prepped l98 heads from a vette. He used that in conjunction with SLPs strongest street legal cam. it was in the August issue of Hot rod.
Here are the specs on the engine that got into the 10s...11s without the 125 shot.
Stock longblock (pistons rods crank)
Accel superram and TPIS big mouth lower intake manifold w 52mm throttle body, original 22lb/hr injectors, FPR, CLP cold air box.
Vette heads w 58cc chambers (milled .025 and ported by SLP)
2.00, 1.58 valves
SLP (51010) stock hydraulic roller w .49/.510 lift and 224/232 duration.
Comp 1.46 dual valvesprings
Stock distrib w MSD 6a and blaster coil.
10 degrees initial and 36 total timing
Hooker Super comp long tubes 1 5/8 headers, 3" tubing w/ Dr gas x pipe and 40 series delta Flow mufflers
11.7 w/o nos
10.9 w nos
On drag slicks and skinnies
TRANNY
original 700R-4 w SLP shift kit, nine clutch pack third gear
2800 Tq converter w 3400 RPM flash
SLP alum driveshaft
Currie built Ford 9 inch w 4.11 gears, 31 spline allow axles
Drag shocks airlift airbags
3128 lbs w driver
Before this guy opted for true duals (non street legal) he was running 12.1 wo the juice.
That is something to go off of for a guy who can drive his car to the track easily. OH...MANUAL STEERING
--Dan
Old Oct 10, 2002 | 11:04 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
About $5, give or take 1¢.
AJ
midge54
Dec 27, 2019 04:14 PM
gta90
Sep 15, 2015 04:00 PM
bdads
Aug 24, 2015 06:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
