Oil pressure
Old Oct 15, 2002 | 07:22 AM
speedfreak85's Avatar
Oil pressure
My car has a carb. 350 and turns 3,000 rpm going down the highway. It runs about 65 psi when it's warmed up and about 85 psi when it's cold. Why so much pressure? Is this a problem? I haven't blown out any seals yet, but I'm not sure if I will or not.
Old Oct 15, 2002 | 07:49 AM
ede's Avatar
ede
not a problem, most engines i do peg the gauge at speed and drop a bit at idle. with a m55 pump and mr g. #26 spring i get 65+ running and 25 or so at idle
Old Oct 15, 2002 | 04:08 PM
Ok, thanks for the input
Old Oct 16, 2002 | 06:06 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
you may have too much oil, or may be running too heavy of a weight of oil.. 85 psi is a bit excessive.. 65 is about right for hard running at a decent rpm but you should be at about 30 psi at idle..
Old Oct 16, 2002 | 06:34 PM
AFRO IROC Z's Avatar
the oil pressure sending unit could be bad. Sometimes it will give you a wacky reading like that, mine used to do the same type of thing then eventually it started bouncing all over the place. try replacing it. not hard to do . hope that helps
Old Oct 16, 2002 | 07:22 PM
89RsPower!'s Avatar
yep thats the most likely cause...my stock sending unit doesnt work for **** it always shows at about 80+psi but with an aftermarket mechanical gage hooked up it reads 20-30 at idle n 60-65 at about 3500 or so
Old Oct 16, 2002 | 10:55 PM
This is an aftermarket gauge, and it was recently installed. Not too much oil, and it's 10w 30. If I get on it going down the track it goes over 100 psi, but, no problems yet.
Old Oct 16, 2002 | 11:10 PM
89RsPower!'s Avatar
are you running mostly stock components? that oil pressure reading sounds way way too high, oil should be pratically squirting out where the gaskets use to be with that kinda pressure.. maybe it is a falty gage or something along those lines.. is it mechanical or electrical?
Old Oct 17, 2002 | 07:20 AM
It's mechanical, and all I really know is that it has a high volume oil pump.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
