balance, blueprint?
As for balancing, the rotating assembly is weight balanced +/- 1 gram or so. Meaning that the rods get weight matched, pistons get weight matched and so on. As for 'blueprinting', the machinist's job is to machine all of the parts to the design tolerences.
What the idea is, is to get the weight of the piston/rod/wristpin to match and the crank shaft counter weights to be a zero balance (along with the clutch, flywheel/flexplate and the harmonic balancer). This is to elevate vibration from something being out of balance.....kinda like a wheel and tire. This assures a long life and smooth operation. Its cheap insurance, thats for sure.....
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
They balance and blueprint what is inside the block.
crank+rods+pistons= rotating assembly.
They balance those parts, but some kits r sold unbalanced.
It saves money.
It saves money.
Car: 4
Engine: 6
Transmission: 5
"Bleuprinting" is bringing all the measurable dimensions of the engine to as close as possible to their design values. For example, the ring end gaps might be .025, +.010 -.000; "blueprinting" might bring all of them to .0026" - .0028". Or, your heads might have a "nominal" combustion chamber volume of 64cc; but if you measure them you might find they're anywhere from 63cc to 68cc, so you make them all 68cc and then mill them .001" at a time until they're all 64-65cc.
Attention to detail. That's what racing really is: it doesn't matter what you're racing, be it horses, car, dogs, motorcycles, boats, whatever; or whether it's round track, straight track, endurance, desert off-road or whatever; racing is a state of mind and an attitude. Attention to detail. That's what separates the guys on the podium from the guys that load back up on the trailer on Friday afternoon.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Oops. I replied to the same message in the Motor Swap forum. I'm not retyping it again.
Thanks alot for all the info. I'm trying my first full rebuild now. This is just gonna be a summer vehicle. Not looking for race tolerences. Is it necessary to get it balanced/blueprinted. Is it overkill, a good idea, or absolutely, necessary?
Chevykid810
Sep 28, 2015 12:57 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
