how to check spark?
Old Oct 16, 2002 | 07:31 PM
Raiden's Avatar
how to check spark?
I recently took off one of my plugs and it did notchange the idle quality? I then did the same to 4 more others... no change. Can anyone tell me how to tell to see if my engine is firing properly?
TYTY!
Old Oct 16, 2002 | 07:34 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Start the car, and take them off, if you get shocked, then you're getting spark..
Just take a screwdriver stick it in the end of the wire, then lay it off to the side somewhere, near metal, and crank the engine, you should see a spark arcing.
Old Oct 16, 2002 | 07:58 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
you have an inductive timing light?
Old Oct 16, 2002 | 08:11 PM
ede's Avatar
ede
with a spark checker, if it jumps the gap you have spark and you have a spark with enough strength to fire the cylinder
Old Oct 17, 2002 | 01:21 AM
Raiden's Avatar
I have done the mention methods including getting shocked!:lala: I do have an induction timming light. I removed one wire at a time, put an old plug wire on to an old plug and got spark in all cylinders. But what i can not figure out is my idle quality is fine when i disconncet a plug wire? does not matter which one???
What can i do with an inductive timming light to check for spark?
Old Oct 17, 2002 | 03:31 AM
ede's Avatar
ede
the ecm makes adjustments for the dead hole. long time ago when i took a class for scanners and computer controls the instructor removed 3 plug wires from a 3.8 grand prix and it never changed the idle
Old Oct 17, 2002 | 07:50 AM
easiest way I know to check for spark is to clip my timing light onto each wire while the motor is running- you will instantly know whether you have spark going to each cylinder.
Old Oct 17, 2002 | 09:54 AM
jimmy_mac's Avatar
Like has been said the ecm will help keep the idle good with one plug wire not firing, but put a load on it and you should notice.
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
djmarch
Aug 19, 2015 12:07 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
