to much vacuum
Old Oct 18, 2002 | 07:03 PM
bills82z28's Avatar
to much vacuum
I jst installed a comp cams xr264hr-10 & I keep blowing my pvc valve off.WHY?Thanks in advance.I just have to say I LOVE my Z28 it down right halls A@@.
Old Oct 18, 2002 | 07:14 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Re: to much vacuum
I thought mine comes up a little, but never blows off.
oh and A@@, don't you mean A$$
Old Oct 18, 2002 | 07:17 PM
bills82z28's Avatar
yup
Old Oct 19, 2002 | 07:57 AM
Vader's Avatar
That sounds more like too much crankcase pressure and/or not enough vacuum, to me. What is the idle vacuum reading, anyway?
Old Oct 19, 2002 | 08:01 AM
Car: 99 Formula
Axle/Gears: 342
I was thinking the same about not enough vacuum, as in there isn't anything sucking/holding it down.
Old Oct 19, 2002 | 08:47 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What exactly is "blowing off" of what?
You may just need a new rubber bushing where it fits into the valve cover, or your hose to it may be misrouted such that it's always trying to pull it out. Vacuum has nothing to do with "holding it in", or anything like that.
Old Oct 19, 2002 | 02:54 PM
bills82z28's Avatar
I have a hose from my edelbrock carb to the valve cover with a pcv valve on the hose,it keeps coming off from the valve cover.I'm afraid if I keep driving it I will blow the rear main seal.& I just have to say it haul's a$$.
Old Oct 19, 2002 | 03:53 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Is the PCV working (sucking air)?
Is the breather on the other valve cover obstructed? It should be connected to filtered air somehow.
If the breather is obstructed AND the PCV is not opening, you could be generating enough crankcase press to push out the PCV due to normal amounts of blow-by.
If all the above is OK, your new cam may be contributing to increased blow-by due to the higher cyl pressures being generated.
A compression check should tell you if there's a major blow-by issue.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
