Rough running after header install?
Old Oct 25, 2002 | 02:49 PM
MikeS's Avatar
Since I installed SLP 1-3/4" headers (no AIR) on my car (87 Trans Am 305 TPI), it has been running very rough, sometimes rough enough to stall at idle. I've searched the boards for things to check. Checked the O2 sensor. I haven't checked the signal sent, but know the connection from sensor to ECM is good. I haven't checked the signal it puts out since the sensor wasn't bad before so shouldn't be bad now. Checked TPS setting. Perfect .54 volts. I'm headed out to put new plug wires on now. Anybody have ideas other than what I've done?
Thanks,
MikeS
Old Oct 25, 2002 | 03:22 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Plug wires are a start, but what about the plugs themselves? It's possible you could have broke one or a wire is sitting on the headers.
Old Oct 25, 2002 | 04:57 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I would guess the wires or plugs also. Maybe one ic cracked, or one of the wires was pulled off the socket. There really isn't anything much that can go wrong when installing headers. Well, I say that, but I have never done it on a TPI car, so I could be wrong. I would look at the plugs and wires. If its close to tune up time, buy new ones anyway, and see if it helps.
Old Oct 25, 2002 | 09:25 PM
MikeS's Avatar
I'd never installed them on a TPI car before either. I got all my wires made up, but it got dark before I could put them on. As far as plugs go, I put in new ones after the header install was done, so don't expect any problems there. I had an code 13 when I pulled codes the other day (oxygen sensor circuit), but when I erased the codes it didn't come back. So, I'm really hoping these new wires help out. Once again though, the old ones worked fine before the header install, so I don't see why they wouldn't work just as well after.
At least you guys are thinking along the same lines that I had been. It feels like ignition problems. I just don't understand why I would be having any. I'll be getting up early tomorrow to put the new wires on. I'll let you know how that works out.
Thanks,
MikeS
Old Oct 25, 2002 | 09:44 PM
88GTAinRI's Avatar
From: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
firing order? 5&7 are close in firing order. Made that mistake once. I would also agree with checking for cracked plugs or burnt wire. I started my engine up 2 weeks ago (SLP 1 3/4) and burnt a wire. Just finished taking the left side apart tonight to replace wire and a gasket tomorrow.
Old Oct 25, 2002 | 10:05 PM
MikeS's Avatar
88GTAinRI,
Good idea. I marked the wires as I took them off but will check everything again in the morning.
Old Oct 25, 2002 | 10:10 PM
MikeS's Avatar
edit: triple post or something
Old Oct 25, 2002 | 10:49 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yeah recheck those wires, I know I crossed 2 of mine up and caused backfires thru the exhaust.
Old Oct 28, 2002 | 11:22 AM
MikeS's Avatar
Well, sure enough, that did it! Runs much better now. If only I can hurry up and get some brackets on my exhaust to keep it off the speed bumps, I'll be set.
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
customblackbird
Aug 15, 2021 10:16 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
