which head gasket?
Old Oct 26, 2002 | 11:39 PM
fearsomepirate's Avatar
which head gasket?
Is the $18.99 pair of Mr Gasket gaskets available from Advance Auto any good (1988 GTA 350), or should I get something else. And don't tell me to get the expensive performance gaskets because I just can't afford it.
Old Oct 27, 2002 | 12:21 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
My machinest, whose has been building roundy-rounder SBC motors for 30+ years, recommends the regular ol .039" thick FelPro gaskets.
That's what I'll be buying next week.
I haven't priced them lately, but expect them to be competitively priced.
Old Oct 27, 2002 | 07:30 AM
ede's Avatar
ede
unless i have aluminum heads on an iron block i use the factory replacement from fel pro. fel pro is all i buy or use and never had a gasket related problem if i do my part right.
Vader's Avatar
Your local GM dealer should have several pairs on the shelf, and they will likey be cheaper and fit better than the FelPros. I discovered an "issue" with FelPro gaskets when working with World SRTorker305 heads, and two World Products engineers basically stated that the FelPro designs aren't always current. GM incorporates improvements BACKWARD into their parts, so your replacement gaskets should be a better fit and quality. Unless you really want to change the compressed thickness for some reason, stay with the originals.
Old Oct 28, 2002 | 08:33 AM
Wouldn't head gaskets from the dealer cost a lot more? The reason I am saying is because FelPros are about $20+ apiece, and Mr Gasket is $18.99 for the pair.
Old Oct 28, 2002 | 07:11 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Check summitracing.com.
I saw them there for $14.95 a set.
Old Oct 28, 2002 | 08:22 PM
rezinn's Avatar
Do you really want to buy cheap head gaskets?
Old Oct 28, 2002 | 08:23 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Why not, they're easy to change.
Old Oct 29, 2002 | 07:34 AM
Being as I'm almost broke, yes. Being as I don't intend to race this thing for quite some time (i.e. not until I have money and can put in aluminum heads at which point I will have to put on better gaskets).
Old Oct 29, 2002 | 04:41 PM
holmes677's Avatar
a head gasket for my 305 from my gm dealer only cost me 24.99. The 5 bucks extra gave me piece-of-mind knowing that the factory trusts these gaskets enough to put them on the cars they make.
Old Oct 30, 2002 | 01:04 PM
Eh, I went ahead and ordered the Summit Racing package. 2 head gaskets w/ exhaust gaskets (and intake gaskets that I can't use...had to order the FelPro TPI gaskets) for $26.00...not bad. I figure they know what they're doing.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
