Need to reinstall smog system
Old Oct 27, 2002 | 07:12 PM
abinns's Avatar
I'm having some trouble reinstalling the air/smog pump and EGR valve and tubes. Can't seem to figure out what the pump bolts to. Any Ideas or pictures would be great. Thanks.
Andrew
Old Oct 27, 2002 | 07:56 PM
dantheihatemustangsguy79's Avatar
i'm looking for the same ****. sucks don't it
Old Oct 27, 2002 | 11:32 PM
abinns's Avatar
yup. bought the car and need to install the smog system for cali emissions.
Old Oct 27, 2002 | 11:34 PM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
Abinns, What year do you have here ?
Old Oct 28, 2002 | 01:16 PM
abinns's Avatar
I've got an 87 iroc.
Old Oct 28, 2002 | 07:50 PM
Car: 90 Formula
Engine: 355 C.I.
ok, you have a 87 Iroc..You need info to make it smog legal.. I can get the info you need but I need to know what engine & trans ? I'm a California smog tech
Old Oct 29, 2002 | 01:16 AM
i have a 1991 z28 if you can get me some pics or diagrams that would be great. i have a 5.7 with a4 transmission what ever that is.
1G1FP2382ML123122 is my vin #
Old Oct 29, 2002 | 07:32 AM
Car: 90 Formula
Engine: 355 C.I.
will do
Old Oct 29, 2002 | 01:42 PM
abinns's Avatar
305 ci V8 LB9 - according to the VIN decoder (just got this car)
VIN - 1G1FP21F3HN108897
It's an automatic transmission, other than that, don't know anything about it.
I did finally get the air/smog pump and EGR valves back in and on. I found (finally) where the bracket bolts to the block on the underside of the pump. Then everything fell in to place. But unfortunately the wires that go into the EGR valve seem to be missing....
Thanks for all the help, and sorry about the vagueness of my previous posts. I'm working on this for a friend (who is paying me thank ***) and after a little searching on the board realized that there are many different makes of the car. I own an 91 MR2 Turbo, the only different makes on my car and Turbo and N/A. Again, thanks.
Andrew
Old Oct 29, 2002 | 08:41 PM
86IROC350NY's Avatar
Orange County
I know that orange CTY NY is a non emissions county. Maybe you can get the inspection done there. I went to Brooklyn to get tested. did you know that it costs $150 to get an inspection there
--Dan
Old Oct 29, 2002 | 10:15 PM
I really only need to know if i have my air switching valve hooked up correctly but i'd like to see pics of stock egr and vacume routing hook ups. for future referance
Old Oct 30, 2002 | 12:34 AM
Car: 90 Formula
Engine: 355 C.I.
Egr vacume goes from a nipple just under the throttle body to the vacume regulator that mounts on the ignition coil bracket on the right rear of the intake. Somewhere behind the right head is the location where the wires should lay.. A twin barrel looking connector . Then from the sensor to the egr for the other hose.. This would be the top of the two.
Old Oct 30, 2002 | 10:12 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
Re: Orange County
--Dan
you live in my county!
dont we need a NJ inspection sticker not a NY?
Old Oct 30, 2002 | 12:57 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
um brooklyn? they will get u whateva u need man. u want an 8 ball with that sticker?
Old Oct 30, 2002 | 02:01 PM
yeah bergen county
BUT, I go to school in West point NY. That's orange county and it is non emissions.
PM me for info on Bergen county connections.
--Dan
Old Oct 31, 2002 | 12:31 PM
abinns's Avatar
Well, everything is installed but the air tubes that go from the Check Valve of the Smog Pump to the various locations.
Does anybody have a picture taken from the left front fender down into the compartment? Anybody know where I can find one? Hopefully it will still have smog stuff there. But even so, it might help.
Andrew
Old Nov 5, 2002 | 07:20 AM
Car: 90 Formula
Engine: 355 C.I.
I'll see what I can come up with for you
Old Nov 5, 2002 | 11:26 AM
so on the air switching valve i have the tubes from both headers going into the inbd side of the asv and the tube that takes it to the cat on the outboard side is the the correct routing? the collant stuff will only hook up the way it will hook up so i know that part of it is right.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
racereese
Oct 10, 2015 09:39 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
