AirGap intake
Old Oct 28, 2002 | 12:23 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
AirGap intake
Does anybody run one of these? Does it fir under the hood? How does it run?
Old Oct 28, 2002 | 12:38 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
What is it?
Old Oct 28, 2002 | 02:22 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
It's an intake manifold.
Old Oct 28, 2002 | 02:50 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Ordered mine yesterday. Doubt it will fit under a stock hood though without a drop style aircleaner and a big one at that. Kind of negates the point of it.
This is to replace my edelbrock performer. From every magizine dyno test I have seen this thing performs awsome. More TQ and HP up to ~5000RPMs and only very little loss after as compared to a vicotr junior.
Kind of the best of both worlds on the single/dual plane intake.
Old Oct 28, 2002 | 03:23 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
its the same height as a standard performer rpm
and under most cases, that will not fit a third gen hood without a drop base aircleaner. Some can fit.. but its not designed to.. thats why gm made a performer type clone for the ZZ4 motor.. so it would fit a third gen without mods.
Old Oct 28, 2002 | 03:27 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
I've had one since they came out. Definite improvement over the std. performer. No way would it fit under a bird hood.
Old Oct 28, 2002 | 06:33 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Well i have a 82 Z composite hood. Currently i have a stock gm aluminum intake with a 1" spacer and a holley 600. I have a drop base aircleaner with a 3" element. I am going to ad my K&N Xtreme airfliter lid when i put in my new motor.
Old Oct 28, 2002 | 06:34 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
I've got the performer rpm (same hieght) and it fits fine under my hood (I also have new motor mounts if your wondering).
Old Oct 28, 2002 | 06:35 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Are you going to get a different carb, with the future setup?
Old Oct 28, 2002 | 07:44 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I don't think i will switch crabs right away, if at all. I might get a 650DP-750DP but its not really worth it.
Old Oct 28, 2002 | 07:45 PM
No4NJunk's Avatar
aaaahhh!!!! You got crabs!!!
Old Oct 28, 2002 | 07:59 PM
Car: 99 Formula
Axle/Gears: 342
lmao.
But I wouldn't get a 750DP, maybe a vac. secondary 750, I was recommended a 650DP, you should notice a good HP gain with one.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
buckshot63
Sep 10, 2015 09:15 AM
toronto formula
Sep 10, 2015 07:31 AM
