305 heads
Old Oct 30, 2002 | 03:30 PM
radiateu2's Avatar
305 heads
416 castings verse a set of 081 that are ported and polished. which are the better castings?
Old Oct 30, 2002 | 03:41 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
I've done the 416's with good results.
Others have done just as well with the 081/083 heads
The centerbolt heds have a better spark plug placement
reaches into the chamber a lil farther.
Both seam to have the same ports
Which is better is really a toss-up
I'd work with which ever came along first
look for flow figures around 240+ cfm in and 180+ exhaust
with 1.94x01.60 valves and max home porting.
Old Oct 30, 2002 | 03:42 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They're about the same. 416 are perimeter bolt, 081 are centerbolt and have th elater model style intake bolt holes.
Old Oct 30, 2002 | 03:43 PM
radiateu2's Avatar
ported
I ported the hell out of my 081 its amazing how much you can actually take out of the intake ports and how much you can open the exhaust ports on these heads
Old Oct 30, 2002 | 03:45 PM
F-BIRD'88's Avatar
Re: ported
Yes as long a s the casting does not have bad core shift
you almost can't screw up ( break through)....
Lots of meat there
Old Oct 30, 2002 | 03:47 PM
radiateu2's Avatar
porting
If you break through can you use epoxy to fix it. I havent done this just curious if there is fix for it
Old Oct 30, 2002 | 03:50 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Lots of meat there
yeah tell me about it. I was grinding away at mine when.....oops....I'm not supposed to see through there am I?!!! Real bad core shift on one of mine. But the other was just fine. I got another 416 for practically nothing.
Old Oct 30, 2002 | 03:52 PM
radiateu2's Avatar
really
Really I didnt break through just wondering if there was afix for it without getting another head lol
Old Oct 30, 2002 | 04:31 PM
F-BIRD'88's Avatar
You can repair a intake port with epoxy putty,
and an exhaust port with "Thermo-Steel".
Thermo-Steel is made of the same stuff as Muffler Cement
but with iron fileings mixed in. 2400*F,,, neet stuff.
http://www.cargochemical.com/main.htm
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
