car keeps trying to start after turning it off..help
Old Nov 4, 2002 | 09:36 PM
1987chery z's Avatar
i have a 87 berlinetta and today after cleaning the carb it, it didnt want to stop running after turning the ignition.....its weird because i disconnected the battery from the engine and still it was trying to start. i also took all the spark plug wires out from the distributer and still......it finally died after almost 25 min.....i had to keep watering the cats because the pipes were all red from the heat. ................please help..i have no idea what happened and what might have cause my engine to keep wanting to start ....suggestions and ideas are greatly appreciated.
Old Nov 4, 2002 | 10:01 PM
Killogy's Avatar
Car: 87 Firebird Formula
Engine: 355
My car does that sometimes when I try to shut it off when its still on the choke and the idle is too high. Try tapping the gas a little before you shut it off to get the RPM's down. I got a stiffer throttle return spring and that seemed to help too.
Old Nov 4, 2002 | 10:06 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
It's called dieseling.. Occurs from a too high idle, or excess carbon buildup.
You can mist some water into the carb, to clean things about a bit, if it's carbon buildup.
Hmm, red cats too?? sounds like either a lean problem or a clogged cat.
Old Nov 4, 2002 | 11:50 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Your timing is advanced too far or your idle is set too high. Try shutting it off with the car in gear until you sort it out.
Old Nov 5, 2002 | 03:27 PM
Vader's Avatar
And in the process of "sorting it out", you'll probably have to lube the choke linkage, readjust he mixture control solenoid, idle stop screw, high idle stop screw, and check the TPS voltage.
There may also be a high idle solenoid on your carburetor (not sure on your car) that reequires adjustment after everything else.
Later,
Vader
All my life I've been searching for something. Something never comes - never leads to nothing...
Old Nov 6, 2002 | 12:48 AM
thanks guys ..i appreciate your replies...ill try the suggestions and ideas out and keep you guys up dated...thanks again
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
djmarch
Aug 9, 2015 05:27 PM
