Cam for a 305?
Old Nov 7, 2002 | 02:46 PM
0cP's Avatar
0cP
Cam for a 305?
Got a chevy 305 from a 92 caprice gonna swap it in to my chevy astro van ( http://www.astrosafari.net/ if anyone wants to know more about V8 astros) the engine is stock now I'm gonna put hedman headers on it and run a true dual 3" exhaust and will run the TBI intake. I'm thinking a preformance cam would be a cheap way to gave a big boost in hp and wanted to know if any of u guys have done this with 305s and what you would recommend?
Thanks ocp
Old Nov 7, 2002 | 05:38 PM
Buck268's Avatar
I'd just drop a LT1/LT4 cam in there. Fairly computer freindly, decent power increase, and no excessive lift. Plus, you can pick up a used LT1 cam for $50 or less...
Old Nov 7, 2002 | 05:43 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Dual 3'' exhaust is going to be way overkill for that engine.
Old Nov 8, 2002 | 12:39 AM
laegion's Avatar
Car: 84 Trans Am Ws6
Engine: 305 LG4 "H.O."
Transmission: wc t-5
edelbrock makes a cam specifically for the 305 with low lift on the intake to keep the power from being out of it's rpm range, gives a decent increase according to desktop dyno.
edl-3702
total lift .398/.442
duration @ .050 194/214
Old Nov 8, 2002 | 01:49 AM
89WS-6's Avatar
Maybe its just me, but your registered, to ask about cams in a safari van???? (confused)
Old Nov 8, 2002 | 05:57 AM
Buck268's Avatar
he's asking about 305 specific cams as he is going to be swapping a 305 into his Van. Personally, I think its a waste to go through all that effort for a 305, and I think he should through a 350 in at least.... Thats because my dad has a 1997 Safari, and the Vortec 4.3 (I think its 4.3) V6 puts out 190hp, and 245 ft-lbs of torque... VERY comparable to stock 305's, so I'd assume it could be built comparably to 305's... Just my opninion...
Old Nov 8, 2002 | 06:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've had great success with Summit's SUM-K-1102. Note my sig. Total lift: 420/442, Duration: 204/214.
JamesC
Old Nov 8, 2002 | 08:20 AM
0cP's Avatar
0cP
Yeah I wanted a 350 but they were just too much money and with my 4.3L having a blown headgasket I didnt feel like rebuilding it. So I looked around and found out it was cheaper to buy a 305 then a 262, must be alot of 305s around. Now I'll have that nice V8 sound in a minivan .
Old Nov 8, 2002 | 11:50 AM
Buck268's Avatar
yeah, I can see where your coming from... 305's do go for cheap...
Old Nov 8, 2002 | 04:31 PM
laegion's Avatar
JamesC
the only problem with a cam like that for a 305 is that it puts the peak power up in the higher rpm ranges not to mention doesn't have a very flat torque curve. which is bad for a car that's heavy and has bad gearing like a minivan.
the edelbrock cam was designed to give a 305 a nice flat torque curve, and to keep the peak hp, and tq down at a level reachable to a 305 with a stock bottom end and valve train.
it's the cam I'm going to use in my t/a when I rebuild the 305.
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
