Vacume Line Help
Old Nov 7, 2002 | 05:16 PM
Eat_um_up's Avatar
Vacume Line Help
I live in Cali and i bought a car from out of state. Unfortionately here we have those nice (HA!) smog laws and the car didnt have any smog So I bought a new motor with all the smog on it. Now i gotta figure out how to hook it all up.
well My car is an 82 T/a. It had a Vaccume advance Distributer withthe coil mounted on top of the distributer. Is that car supposed to have a vaccume advance? Does any of yours? There does the vaccume line from the distributer plug in at if so? Thanks
James
Old Nov 7, 2002 | 06:31 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
this help?
Old Nov 7, 2002 | 06:34 PM
Eat_um_up's Avatar
That helps a lot actually as im trying to figure this mess out. I just have one dumb question
is the vac sensor on the top right the vaccume port on the distributer?
Old Nov 7, 2002 | 07:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Your car is not supposed to have a vacuum advance distributor.
The thing at the top right is the computer's vacuum sensor, otherwise known as the MAP sensor. It's a little box that should be mounted on the firewall behind the brake booster.
Old Nov 7, 2002 | 08:02 PM
Eat_um_up's Avatar
So i take it that this vehical did not have a vacume advance distributer as a stock feature?
Old Nov 7, 2002 | 08:32 PM
SHAGME's Avatar
Car: 1988 IROC-Z
shoot srry that is for a camaro Ive got to find the one I have for a TA
Old Nov 8, 2002 | 02:20 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Im still looking for the diagram 4 u. my pc crashed so I need to recover my hardrive. see if the local dealer has one they might.
Old Nov 8, 2002 | 10:28 PM
Vader's Avatar
The T/A should have had the dual-snokel:
But that car should also have had an Electronic Spark Timing system and no mechanical nor vacuum advance distributor.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
