Evaluate my motor buildup...
Old Nov 9, 2002 | 04:28 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I am thinking about what motor I want to put in the TA when I get the money saved (a year from now) and figured Id beter start asking questions soon so I have a head start on knowing what I will do.
I was going for 500HP at 7000 Plus RPM from a nascar style bore to stroke ratio. I was thinking about a bowtie or similar block with a 4.125 bore and putting in a nascar crank from musclemotorsports with a 3.335 stroke.
carrilo rods, 240cc runner heads, havent considered pistons yet but almost certainly over 10 to 1 compression for 500HP.
I am still deciding what intake and fuel to use but I am not picky. If fuel injection would work I am game.
The questions I do have are about the cam and valve train.
I talked to a guy at the dyno shop today and he said that an 8000 rpm redline is unrealistic because the valve train would cost so much and wear out so often. I thouhgt that was interesting and so I thought I would put this to you guys to see what you think.
should I bring my RPM goal down and go with a longer stroke?? or could I get away with this kind of rpm?
BTW this would be a total toy car and not my daily driver and would be backed by a manual trans with 3.42s at least in my 3200lb car.
Thanx.
James
Old Nov 9, 2002 | 09:20 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
One question why do you want to run the engine up that high to create power. It would have no torque and would be lazy on the street.
Old Nov 9, 2002 | 09:43 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I dont think it would be too bad down around 2-3K but I really dont know why you couldent get at least 200ft-lbs at 1500 while making peak torque above 4500 or higher.
in my eyes that would be as streetable as I would need for the cruising and racing I might do with it. its not like I would drive this thing to work. just take it to the strip once in awhile and road race on weekends.
is it so unrealistic to think that I could get usable torque below 2000 rpm while still getting peak HP above 7000?
Old Nov 9, 2002 | 09:55 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I would definitely use a solid roller cam for that setup. Probably a comp cams XR292R. Build it with good springs and some good roller rockers like comp Pro Magnums.
Old Nov 9, 2002 | 10:10 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Actually now that i think about it, that would be a cool setup. That is if you could afford all of the top dollar components that would be needed.
Old Nov 9, 2002 | 10:11 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I like the Idea too...
BTW I am looking up your cam selection but the dialup is kinda sloooowwww..
{edit}
ok I was thinking alittle more duration like 265 and WAY more lift like .650 or so.
to get out of the box 240cc heads to flow well at 7000 I think you would need at least .600 lift and over 260 degrees of duration at .500
but I am not experienced at picking cams.
Old Nov 9, 2002 | 10:14 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I ran that setup through DD2000 and cam up with more than 500 hp form 5500rpm to 9000rpm.
I used:
Dart Pro 1 230cc runners
Comp XR292R
Race headers
900cfm carb
Old Nov 9, 2002 | 10:16 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
oh cool you have DD ...
dude I have lots of specs for parts -- could you run them for me?
Old Nov 9, 2002 | 10:19 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Sure name some setups.
Old Nov 9, 2002 | 10:24 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
im not sure what specs you need but the cam choice you made seemed to give HP that was a little high in the rpm range than what I had in mind.
how about something with a little less duration and more overlap angle like 112 Degrees??
and where was the torque peak and what kind of torque did it make under 3K??
Old Nov 9, 2002 | 10:33 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Rpm HP TQ
2000 110 288
2500 164 345
3000 211 369
3500 265 397
Peak TQ 496 @5500
HP 587 @7000
Old Nov 9, 2002 | 10:39 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
wow that sounds great!!
why dont you try this setup...
same short block
pro topline 242cc alum heads
and a cam with 112LSA 250/255 at .500 lift with .600 total
and a smaller carb like 850
Old Nov 9, 2002 | 10:42 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I changed to a XR274R and get much better lower end torque without much lose in peak power.
553 HP @ 6500 rpms
504 TQ @ 5000
Old Nov 9, 2002 | 10:45 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
so let me get this straight you have to pick from a list of existing grinds that DD gives you??
Old Nov 9, 2002 | 10:46 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I don't have a head flow file or the Pro Lightning 242's. But i do know that you don't need a head even close to that big to make 500 hp. I think it would be way over-board. The Pro Lightning 200's can support more thatn 550hp.
Old Nov 9, 2002 | 10:48 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
No i can enter custom specs. But these are good cams. If i knew the head flow numbers for the pro lightning 242's i could make a file for them, and use them in dd2000.
Old Nov 9, 2002 | 10:49 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
ok then the dart heads are definately fine for this setup but I would like to know what a little more lift and LSA would do to flatten out the torque band and get HP peak back up to 7000 while giving the 200 ftlbs at 2000. I guess this would be a custom grind but if you can find a similar cam DD it.
Old Nov 9, 2002 | 10:50 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
or maybe go with 1.65-1.7 roler rockers
Old Nov 9, 2002 | 10:52 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
i tired used the cam specs you gave assuming a roller cam and got. Using same setup as before only changing cam.
578 HP @6500
501 TQ @5000
A smaller carb does nothing at all, maybe 5hp.
Old Nov 9, 2002 | 11:02 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
hmm well thanks a bunch for the info.
this really is encouraging news on the streetability of this setup but I still have to figure out how long the valvesprings would last.
and I think just from the couple of minutes spent on picking cams that I could find a grind that would make HP peak at 7K and 200ftlbs at 2K.
maybe the XR280R with .600 of total lift.....
or better yet the 300AR spec--> 300/300 adv. 255/255 @ .500 .575 max 110LSA
Old Nov 15, 2002 | 09:22 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
anyway I just got DD2k and ran a bunch of combos and I know that the program is supposed to be optimistic and it also does not account for driveability problems related to poor atomization and vacuum but see what you think:
4.125 dart block with 350 mains
3.335 bryant crank
6" carrilo rods
Flat top pistons (havent found - probably custom)
230CC Runner 64 cc chamber dart pro 1 heads
~10.92 Compr ratio with .042 gaskets and zero piston height
Comp 280 AR solid roller 280/280 at .55 lift and 110 LSA with 1.5 RR
I ran this combo with a tunnel ram type of manifold at 1000CFM and got over 350 ft/lbs at 2000 rpm (as good as the TPI I got now) and over 500 HP from 5500 to 7500 RPM.
I was thinking that the holley stealth ram might be a good approximation to this because I have read that the runners support 300CFM and I dont think I will need that much because I am not even hitting the dart heads opitmal flow lift at over .7"
because the valve lift is under .6 and the duration isnt crazy I think that this motor could work for a light street/road race car.
but what do I know....
File Type: bmp
Old Nov 19, 2002 | 02:41 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
One thing to remember is I think DD2k is off on tq figures. I seen an article in a magazine on this once.
Also another thing to remember is DD2k doesn't at all figure in cfm of a carb being too big. So in theory I could make a 305 with 1000cfm carb and it would work fine on the program... while that is way to much for a irl motor. They figure the carb you pick will run perfectly on that motor.
Also if you read the tutorial, like 136 pages long... not much of us have that much time... but anyways they say you don't make any difference in tq with longer rods such as 6.0 instead of 5.7 inch rod... just another thing
I called into Comp Cams about getting a cam for my new motor:
383
4340 forged and balanced assembly
trw flat tops 10.7:1 comp
210cc AFR Race Ready 2.08 and 1.60 valve heads
victor jr intake with 2 inch HVH spacer and a 750 demon on top
They said would probably need xr274r but I'm thinking about calling back in and seeing if xr280r will work better. With 1.6 rockers that gives me a .608 int and .614 exh lifts.
I think a 3k stall would work fine on the street. I'm running a 9 1/2 inch 2400 stall right now with my peanut cam and 3.27 gears in a daily driver right now.
Old Nov 19, 2002 | 05:30 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
yea that all makes sense.
I have a while to go before I build this motor anyway so I will probably end up getting several tens of opinions on it before I spend the first dollar.
skip91
Sep 24, 2015 03:29 PM
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
