if i have this compression with these heads??
Old Nov 18, 2002 | 09:36 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey guys if i have 8.5:1 compression with 72cc heads then wut woudl i have if i used 64cc heads? thanks
Old Nov 18, 2002 | 09:50 PM
CR-SuperChevy's Avatar
im running 63cc heads and i was told 10:1 to 11.1 depending on other factors 94octane
Old Nov 18, 2002 | 11:43 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
9.16:1
Old Nov 18, 2002 | 11:55 PM
CamaroDriver's Avatar
http://www.smokemup.com/auto_math/compression_ratio.php
Old Nov 19, 2002 | 07:06 AM
ede's Avatar
ede
camarodriver check your PMs, thanks
Old Nov 19, 2002 | 07:55 AM
TBI305Camaro's Avatar
I have no idea how to use that...could someone tell me if lo5 heads are 58cc or 64cc?
I have 9.6:1 right now with lo5 heads...are they 64cc? if so can you see how much compression id have with 58cc heads.
Old Nov 19, 2002 | 09:07 AM
Vader's Avatar
Engine Calculations.xls .
It works better with Quattro Pro, but will work with MS Excel.
Old Nov 19, 2002 | 05:50 PM
loudpedal's Avatar
Car: DAF
Engine: 3 cyl 2 cycle
Transmission: variable speed
try this..
site for a really good c.r. calculator...
www.kb-silvolite.com
click on cr calculator and plug in your figures.....HOWEVER..
You will only be close if you guess at the numbers that you input.
To find out whats the deal inside that motor you have to cc the heads, measure the deck, etc etc etc.
Old Nov 19, 2002 | 06:03 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
i think the lo5's are 64 cc heads
Old Nov 19, 2002 | 09:11 PM
If they're #14102191 or #14102193 then they're 76cc chambers.
Those are the casting #'s they used on the LO5 engines so more than likely that's what you have.
www.mortec.com/castnum.htm
Old Nov 19, 2002 | 09:29 PM
Makaveli's Avatar
thanks vader that excell thing was just wat i was looking for lol
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
58, 64, cc, lo5
