Dieseling after shutdown sometimes....any ideas??
Old Nov 20, 2002 | 09:39 AM
TBI305Camaro's Avatar
Ok here is my setup.
9C1 lo5 350ci
l98 cam
stock lo5 heads
holley street dominator intake
holley 670cfm street avenger
complete dual exhaust with longtubes
After I have been on it alittle stop real quick and kill it it usually diesels just alittle...now sometimes when just driving it diesels alittle. Seems like its gotten worse since its gotten alittle colder...
any ideas? timing isnt to high i only have like 6 degrees base.
fuel pressure is at 5psi, and idle in gar is 750 and in P or N slightly over 1k
Old Nov 20, 2002 | 09:53 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
How is your idle? If it's too high that's the cause.
Since you say the timing is fine.
Old Nov 20, 2002 | 02:44 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
High idle speed, timing, and carbon deposits in the combustion chamber are the most common reasons.
Old Nov 20, 2002 | 02:55 PM
Car: 99 Formula
Axle/Gears: 342
With a brand new motor, I hope he doesn't have any build up.
Old Nov 20, 2002 | 02:58 PM
99Hawk120's Avatar
Where's he say the motor's new?
Old Nov 20, 2002 | 03:18 PM
Car: 99 Formula
Axle/Gears: 342
He didn't I don't think, I just know he has one, I didn't expect you to know.
Old Nov 20, 2002 | 03:35 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
try lowering your idle just a tad. my car idles at about 700 in park/neutral and about 550 in gear. makes it sound better lol
Old Nov 20, 2002 | 03:39 PM
TransAm's Avatar
From: Somewhere in between Lynn, MA (home) and Lakeland, FL (school)
What kind of gas are you putting in? My car acts up if i put anything less than 93 in it... (dieseling, spark knock and such)
Old Nov 20, 2002 | 08:02 PM
Yeah better not be carbon deposits....
Idle is at 750 in gear and 1000 in P or N
Only way i can lower it is to go with less FP or less timing...my idle screw isnt even touching my linkage and my fast idle screw is backed way out.
and i run 92-93 octane/.
Old Nov 20, 2002 | 08:08 PM
Car: 99 Formula
Axle/Gears: 342
1000 in P is too high.
Old Nov 20, 2002 | 08:57 PM
racing_dude_17's Avatar
Hey TBI305Camaro, Sorry but this a little off subject but imm building a 350 and I have the street dominator and i was wondering how you liked it, thanx
Old Nov 20, 2002 | 09:00 PM
I like it...looked like a real good manifold plus it has a idle - 7200rpm powerband so its all ill ever need. It TALL tho...i can barely fit a street dominator intake, 670 SA carb and any aircleaner under the hood...has to get a drop base.
the idle is kinda high but what can i do about it?
Old Nov 20, 2002 | 09:10 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If the car will run at that speed with the idle speed screw adjusted all the way out, There must be air entering the manifold some other way.
Probabily a vacuum leak.
Old Nov 20, 2002 | 09:50 PM
Marshall89ws6's Avatar
when i used to have the 305 it would idle at like 1600 after a cold start then go down to 1000 in p normally and anywhere from 500-700 range in d.
Old Nov 20, 2002 | 10:13 PM
primer84z's Avatar
youve got a vacuum leak. try screwing in your mixture screws all the way. if the car doesnt die, youve definitly got a vacuum leak.
Old Nov 20, 2002 | 10:45 PM
it will die if i do that....ive checked and i cant find a leak anywhere....
with 7psi fuel pressure it idled at 2500rpm....
Old Nov 21, 2002 | 08:01 AM
so where should i check for leaks at? I only have 3 vac lines hooked up...the manifold vaccum, advance from the distributer and the power brakes...ill grab some carb cleaner tomorrow and spray around the manifold and see if its the intake manifold itself.
Old Nov 21, 2002 | 08:27 AM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
You need to fix the reason your Idle screw isn't touching. Idle speed is the reason in almost all cases of dieseling. Timing to fast can make the idle not go low enough... vacume leaks and linkage such as cruise control or throttle cable to tight now with carb change over. vacume leaks and timing cause the diesel because they jack up the idle speed.. carbon build up on a F-body ? Dam I hope you keeper cleanner than that.. a little pedal action to fix that.... hehe
Fix the idle screw problem.. thats where it lies
Old Nov 21, 2002 | 10:53 PM
I forgot that I swapped carbs!!
The idle screw was touching and I backed it off and its idling at 750 in P, N and D now....geez I forgot all about switching the carbs out because I thought it was messed up and idling at 2500rpm (to much fuel pressure).
Oh well all good now.
You guys think 10 degrees advance with the advance hooked up is enough for my motor? 92-93 octane with 9.6:1 compression. What you think?
Old Nov 21, 2002 | 11:53 PM
Car: 90 Formula
Engine: 355 C.I.
Depends.. on if there is vacume to the distributor at idle.. better if it's ported vacume but if you have 10 degrees with it hooked up and there is vacume there then you are way retarded on your timing. I'm thinking you should be running about 6 degrees with your advance disconnected. What kinda plugs are you running ?
Old Nov 22, 2002 | 09:09 AM
Im running those accel U-groove header plugs. I think I am running around 6 with the advance disconnected. The distributer is a brand new proform High performance HEI. Says its has a advance suitable for high performance.
I pulled the plugs yesterday and they still look perfect. None are fouled or anything. No ash or black so I do not think im running either to lean or too rich.
Old Nov 22, 2002 | 09:23 AM
99Hawk120's Avatar
If you're only getting 10* at idle that's kind of low... I'm running about 18* base + 18* vacuum... of course, I've probably got a lot bigger cam than you do.
Try bumping the timing up a tad... it can't hurt.
Old Nov 22, 2002 | 09:50 AM
Im only running the l98 cam so it isnt very big. Ill adjust the timing some more but I dont want to get knock....don't want to trash this engine just yet.
Old Nov 22, 2002 | 10:00 AM
99Hawk120's Avatar
When I had the computer in the car, it adjusted timing at idle to be 40 deg at idle. I'd suggest figuring out your mechanical advance curve exactly... IE, base timing of 6* at 600rpm, mechanical advance starts coming in at 800rpm, all in by 32* 3000rpm, so total mechanical advance would be 26*.
Honestly, you're not going to get knock from 40* of timing at cruise in MOST cases. Hell, I'd try manifold vacuum, but you may have to bump the base timing up a little so that it doesn't retard the timing too much coming off idle. I'll be the first to say my timing curve isn't optimized, but I'd be willing to bet i have like 45* advance at cruise and I don't have any knock.
gta892000
Aug 11, 2019 11:16 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
