Why does my car backfire?
Old Nov 24, 2002 | 02:28 PM
IceBlue91z28's Avatar
Car: 1991 Camaro Z28
Transmission: Built 700r4
When I romp on it and then let off the gas, my car backfirse pretty loud and sometimes shoots out flames. This only started recently. What could this be? could it be my fuel pressure is set to high? plugs? i have no idea and I wana get this fixed because I dont like flames coming out my pipes so please help...thanks
Old Nov 24, 2002 | 03:16 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Do you have any bad exhaust leaks? I know mine did it when I had a blown gasket.
Old Nov 24, 2002 | 04:15 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Sounds like the timing could be off, a rich condition, or a vacuum leak. Your obviously not burning enough HC off or else you wouldn't have the problem. Either your plugs are gonners or your getting too much fuel. Check to see were your timing is at also. Header leak is a big possibility. Do you still have A.I.R??
Old Nov 24, 2002 | 08:57 PM
it is either the plugs, because they are old, or it could be a header leak. I havent checked the bolts in a while since i put them back on so they might be loose. How does a header leak cause backfire. Also, i reloved my car and there is a small leak down there but I dont think that could be it because that has been like that for years. So it could be a header leak?
Old Nov 24, 2002 | 09:04 PM
Car: 99 Formula
Axle/Gears: 342
do you hear any ticking noise?
Old Nov 24, 2002 | 09:58 PM
pskel350's Avatar
when i still had my 5.0 thunderbird i had that same problem when i put on dual exhaust and took out the cats. so i changed to the bocsh single platium plugs and went one step higher in temp and it never back fired again. so you might just want to try new plugs.
Old Nov 24, 2002 | 10:01 PM
it makes a weird noise coming from the engine noise that kinda sounds like ticking but not like pushrod ticking kinda just like weird ticking idk what that is either
Old Nov 24, 2002 | 10:02 PM
Car: 99 Formula
Axle/Gears: 342
pushrods shouldn't tick, lifters may, sounds like you may have some exhaust leaks..
Old Nov 24, 2002 | 10:48 PM
No4NJunk's Avatar
The reason an exhuast leak causes backfiring is because Hydrocarbons (fuel) need oxygen (and spark or high heat) to burn (or break the bond between the Hydrogen and carbon). There is a lack of oxygen usually in an exhuast system but with a header leak providing oxygen and plenty of heat the gas explodes resulting in the backfire you hear.
Old Nov 24, 2002 | 10:49 PM
No4NJunk's Avatar
HOLY ****!! Mark's a moderator!! OMG.....I'm speechless. Whats the world come too . How long have you been mod mark?? What board? Damn. Congrats man!!
Old Nov 24, 2002 | 10:54 PM
Car: 99 Formula
Axle/Gears: 342
few weeks, new regional board, why haven't you checked it out yet, azzhole,
Old Nov 24, 2002 | 10:58 PM
well that exhaust thing makes a lot of sense actually so I am gona check all my exhaust for leaks and check the plugs and I am sure it will be all set thanks
Old Nov 25, 2002 | 10:41 AM
Vader's Avatar
Actually, what you are describing is "afterfire", not "backfire". True backfire occurs when the popping is in the intake tract, not the exhaust. Either way, you are running a rich exhaust from either incomplete combustion excessive fuel. Fix the exhaust leaks first, then gfo from there. If you are still using an oxygen sensor, the exhaust leaks will contribute to a rich mixture condition.
And yes, Mark is now among the ranks of those who aren't allowed to have opinions - or at least have to try to express them as tactfully as they can. I think I'm going to go to his board and "troll" around a little just to make life difficult for him. He'll have to learn quickly how to delete, edit, and modify posts without getting reported to the authorities as being a "bully" or hard-***". We'll get him trained yet...
Old Nov 25, 2002 | 11:06 AM
Car: 99 Formula
Axle/Gears: 342
you think i haven't had pranksters already, lol. bring it Vader
Old Nov 25, 2002 | 11:43 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
the ticking sound is probably a loose header....
Old Nov 25, 2002 | 05:53 PM
ok I tightened up my headers and brought my fuel pressure back up. There is one more exhaust leak where one header connects to the y pipe. It still backfires and now is sometimes sluggish under light acceleration. I ordered plugs and I am going to look into a new dirstibuter cap and rotor? anything else that could be wrong with it?
Old Nov 26, 2002 | 01:58 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
the pat I find funny is it says no post whoring and this is comming from the biggest post ***** around.if you are going to call someone an a<x>sshole then do it right mark and don't just go around it. either way having a post ***** as a mod can't be that bad.... just means we can have post ***** threads
Old Nov 26, 2002 | 02:00 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
just leave that to me I think I can manage that one
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
