rear seal
Old Nov 27, 2002 | 04:20 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
rear seal
hey i was wondering how much it would take to fix my oil leak, i think its comming from the rear main seal, but not to sure. i was wondering if i could leave the engien in the car to fix it, and what i would need, thanks.
Old Nov 27, 2002 | 05:33 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Nope, engine has to come out. It will take some amount of time too.
Old Nov 27, 2002 | 05:50 PM
ede's Avatar
ede
it'd help us all a bit if you took the time to say what engine you have. good chance the engine wouldn't have to come out, but the trans would. it also might be a good idea to find the leak before you jump into it.
Old Nov 27, 2002 | 05:54 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Yeah..your right ede, engine type would help. If it is a one piece your laughn' What year would help too.
I have always used the rule of thumb here. If it is your rear seal...I would just go ahead and replace the oil pan gasket and all. After all it is going to begin to leak soon anyway. Domino effect. Once the one start they all start. Just the way I do things, don't like having to do things twice. That's all.
Old Nov 28, 2002 | 08:18 PM
Squeeks83's Avatar
well its a 1985 chevy 350ci, driver side dip stick, it was out of a 1/2 ton 4X4 truck. what else do you all need to know?
thanks
Old Dec 2, 2002 | 06:29 AM
radiateu2's Avatar
seal
If it is the rear main seal and if the engine is 1986 or older you should have a 2 piece rear main seal and the motor wont have to come out. From what you have described from the dip stick placement. Yours has a 2 piece main seal.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
