what heads to use
Old Dec 1, 2002 | 01:40 AM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
Axle/Gears: stock/3.42
what heads to use
I am building a 350 chevy, and am kind of at a loss for what heads to use. I was going to use the vortecs, but the added cost of intake,rockers etc. make it not worth the effort.
anyways here is what i have: 350 chevy bored .040, decked the block .020 to clean it up, crank 10/10, pistons-fed. mog. flat top ( i think the number was hp345???) supposedly 10-1 with 64cc head, cam is a comp xtreme 274 ( 487/490 lift,230/236 duration@050), cloyes heavy duty double row timing chain. the car is an 82 z-28 with 700 trans with shift kit, 3.73 auburn limited slip rear end.
probably to much info but that is it. any suggestions on heads, i have kind of been looking at the world sportsman II. 2.02, 1.60 valves, 64 cc, 200cc. any guesses on horse power output of this setup would be apreciated also. I am hoping for 350 hp????????
Old Dec 1, 2002 | 03:43 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Get some 305 heads from the wrecker, 601, 081 or 416 castings. They are dirt cheap. Then do them according to the instructions at the end of my sig. They'll flow like Vortecs and only cost around $400
Old Dec 1, 2002 | 09:03 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
check out www.procylinderheads.com at the flow #s for Pro Lightnings, I just got a set of aluminum assembled ones for $880 shipped from www.proshaver.com , they were on sale though.
The owner said he'd do a group purchase discount at that price.
Old Dec 1, 2002 | 10:31 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
whith the setup i explained above, exiting thru edelbrock tes and flow master cat back, which size head would preform best????? 180cc, 200cc then valves? 1.94/1.50 or 2.02/1.60???????????
Old Dec 1, 2002 | 10:35 PM
Engine: 305-4v
Well, people are getting well over 400 hp with regular old Vortecs. They have 170 cc runners and 1.92 intake - 1.50 exhaust valves.
350 hp will come easier than that
Old Dec 1, 2002 | 10:36 PM
Car: 99 Formula
Axle/Gears: 342
With the 274 cam, I would think you would be fine with 200 cc heads.
Old Dec 1, 2002 | 10:39 PM
Engine: 305-4v
What are you building, a street engine or drag only?
For the street that is a lot of cam on a 350. If you want low rpm torque I would stick with a smaller grind and the 180 cc runners.
Old Dec 1, 2002 | 11:48 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
street with occasional quarter mile run. planning on running about 1900-2100 stall converter also
Old Dec 1, 2002 | 11:56 PM
Engine: 305-4v
If you pick up the current Super Chevy they have an ongoing series called "Danger Mouse." It's a 350 that they are dyno testing with all sorts of different parts. Currently they have Vortec heads, Comp XE 262 cam and Edelbrock AirGap intake on it. It is making 415 hp.
That's why I said to stick to smaller runners and cam. Your daily driveability will be much more fun and 415 hp is a lot more than you are looking for
Old Dec 2, 2002 | 07:20 AM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
anyone familiar with the trick flow??????
i got a glance of that magazine on the rack about danger mouse but didnt get a chance to read into it....sounds like it might be worth my reading thanx....
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
