Head Gasket
Old Nov 28, 2002 | 11:25 PM
R.O.B.'s Avatar
Head Gasket
Does anyone know the stock thickness of headgaskets for 305 TPI engines. Courious to know how much will be needed to mill for Vortec's.
Old Nov 29, 2002 | 08:22 AM
ede's Avatar
ede
.040, why would anything have to be milled to run vortec heads?
Old Nov 29, 2002 | 01:29 PM
NTChrist's Avatar
MY, ede, you've NEVER heard of milling Vortec heads for use on a 305?
You ARE behind the times!
Old Nov 29, 2002 | 07:36 PM
R.O.B.'s Avatar
I have a 305, 58cc heads. If I convert to Vortec's, with their 64cc chambers, I need to compensate for the compression loss. If stock gaskets are .040, I just need to play with my Dyno2000 to figure what it would be with .015 gaskets. (I hear these do exist), I figure if I can keep around 9:1 (stock is 9.5:1), I'll be ok.
Old Nov 29, 2002 | 07:43 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
.015 is in my opinion too thin of a gasket, it's just a metal shim and can blow out. If you're going to get the heads milled anyway, just mill them enough so you have the desired compression with a .040 gasket
Old Nov 29, 2002 | 07:58 PM
R.O.B.'s Avatar
I was actually hoping to avoid the cost and possible alignment problems of having the heads milled. Also gives me the extra benny to use them on a future 350 swap.
Old Nov 29, 2002 | 08:06 PM
ede's Avatar
ede
never cared about doing anything with a 305 to bother learning, guess i know now. i'd worry more about establishing the correct quench then raising the compression a tenth or two.
Old Nov 29, 2002 | 08:12 PM
R.O.B.'s Avatar
How can I establish that?
Old Nov 29, 2002 | 09:00 PM
Guest
Guest
Posts: n/a
Stock 305 gaskets are not .040. They are somewhere between .016 and .019. Do a search, you'll find the correct number.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
