Headlights (both) don't go down!
Old Nov 29, 2002 | 08:24 PM
GilmourD's Avatar
I've already searched like crazy, and got no help for this.
I've got my 86 Firebird almost running again. The car's been off the road for a year, now. Last I knew, the headlight motors worked fine, but today they don't work. Yes, BOTH do the same exact thing, where BOTH used to work fine. I can manually crank the headlights down, and when I hit the switch, they both go up. However, hit the switch again and all I hear is a click and the lights go off. What can cause this? And if possible, include pictures of the actual components/culprits. Diagrams confuse the heck out of me.
Old Nov 29, 2002 | 10:30 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Read this topic:
https://www.thirdgen.org/techbb2/sho...hreadid=142797
Then do a search in the electrical section of the board. There are many good suggestion there.
Old Nov 30, 2002 | 01:20 AM
GilmourD's Avatar
Thanks, I read that already. But everybody keeps saying to look for fuseable links and such, and I look where they say and don't find them... Pics are what I really need.
Old Nov 30, 2002 | 09:39 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I think the problem is with your headlight switch itself.
I had simmilar problems and when I mashed the switch hard enough or cycled it a few times the lights would go down.
Old Nov 30, 2002 | 05:35 PM
GilmourD's Avatar
Been there, done that, no go. It's not the switch, cuz the headlights go on and off fine otherwise, and they go up fine.
Old Nov 30, 2002 | 06:59 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
yes my headlights did exactly the same thing and it was the switch..
Old Nov 30, 2002 | 07:02 PM
GilmourD's Avatar
How can I test to see if that's true?
Old Nov 30, 2002 | 07:07 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
you could remove the trim panel and test the switch but if you got all the way back there and it wasnt the switch you might as well put another one in anyway.
In all honesty I think a little electronic cleaner spray in there would give you some indication.
Old Nov 30, 2002 | 07:10 PM
GilmourD's Avatar
And where exactly am I spraying this? Are you talking about teh switch on the panel that I hit to turn the headlights on and off?
Old Nov 30, 2002 | 07:15 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
yes
Old Nov 30, 2002 | 07:31 PM
GilmourD's Avatar
And where exactly do I spray this contact spray? Through teh switch, or do I have to remove it?
Jk_Under
Sep 2, 2015 10:59 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
