Eliminated all my passenger side pullies
Old Dec 3, 2002 | 01:15 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I only have 4 pullies now. Crank, P/S, alt, and water pump. The left side A/C and smog and tensioner are gone completely. The extra room is incredible. I can get to the water pump hose so easy, along with everything else. Since most people who run an a/c delete pully already have gotten rid of their smog pump this seems like a easier, cheaper, and more spacious way to go.
The belt I used is 3 tenths short of 51 inches
The bolt gets pulled tight to the bracket but doesn't go thorugh the stock bolt hole. It goes on the outside of the bracket. Thus no tensioner needs to be made.
Old Dec 3, 2002 | 11:39 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
pic?
Old Dec 3, 2002 | 03:55 PM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
YES A PICTURE PLEASE
Old Dec 3, 2002 | 06:51 PM
383 rocket bird's Avatar
A picture or maybe a little more elaboration would be great.
Old Dec 3, 2002 | 09:16 PM
Aaron91RS's Avatar
Car: RS
Sorry no pic. Cars 50 miles away on jackstands. I only work on it on weekends. Scanner's 50 miles away with car, but the computer is right here in front of me
Not sure what else you want to know. I completely removed the passenger side bracket. The lower two bolt may have to be put back in the block as they may go in to the mechanical fuel pump area. Not sure but I left them.
Other then that you take a 50 and 7/10's inch serpintine belt and go in the stock location and then just from the crank back under the water pump to the alternator.
Old Dec 3, 2002 | 09:34 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Right, but how does this setup allow you to set the tension on the belt? Do you just use a prybar on the belt to get it on, or??
Old Dec 3, 2002 | 11:06 PM
Aaron91RS's Avatar
Car: RS
I said the alt bolt goes on the outside of the bracket not through the hole. So to put the belt on you just have the alt tight in its stock position. When the belt is on pull the alt tight and put the bolt through outside the bracket. Perfect tension on mine.
Old Dec 3, 2002 | 11:08 PM
PonchoTA's Avatar
If you have all of your loading one just one side of the crank/water pump, etc. you might damage the bearings!!
Maybe consider putting your alt. or something where the A/c or smog pump went.
Just my $0.02 !!
Old Dec 3, 2002 | 11:41 PM
Aaron91RS's Avatar
Car: RS
The way the factory setup is from the crank to the water pump its all to one side already.
Old Dec 4, 2002 | 01:07 AM
Matt87GTA's Avatar
Gracias senor. Makes sense now .
Also, I don't think it will affect bearing life either.....
my $.02
Oh, nice work on this too
redmaroz
Apr 25, 2017 07:14 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
Cameeeero
Aug 20, 2015 03:06 AM
Street Lethal
Aug 14, 2015 08:25 PM
